Bridgeport grinds when put into backgear
Likes Likes:  0
Results 1 to 3 of 3
    Feb 2019
    32
    Default Bridgeport grinds when put into backgear
    Hello All,
    I am sure this has to have been covered in another forum so please link if that is so. But, my Bridgeport J Head round ram seems to be catching a little bit when putting into back gear. If I place a 10 thou shim between the cam ring and the housing that will provide enough clearance. What is the typical solution to this, as the shim will fall out when rotating the cam ring in and out?
    Thoughts?
    Thanks!
    Matt
    Mar 2009
    5,586
    103
    1079
    I have noticed that a light upward force on the cam ring handle while in the back gear position reduces noise.
    Was thinking about making a circular shim.
    Sep 2009
    Phoenix,AZ
    1,853
    2844
    477
    Try tightening the 2 screws in the side of the can ring. AFTER FIRST loosening the little locking screws. No one ever seems to lube that area and the ring will sooner or later wear into the housing,make a shim washer .
