Bridgeport/Heidenhain dro questions
Likes Likes:  0
Results 1 to 7 of 7
    Nov 2018
    UNITED KINGDOM
    Default Bridgeport/Heidenhain dro questions
    Evening.
    I'm fairly new to machining and recently bought a Bridgeport mill with a Heidenhain VRZ 731 but the reader heads are faulty and wondered if anybody have have experience on using any other makes of reader heads as there experience new.
    Was thinking of buying a Chinese cheap dro but would like to use the original Heidenhain DRO.
    Any help would be appreciated.
    Sep 2002
    People's Republic
    4,385
    420
    2670
    nope
    Are the heads actually bad or are the scales dirty or whatever
    cheaper to buy a new Chinese, but it will never be a heidenhain
    Mar 2009
    5,586
    103
    1079
    Quote Originally Posted by Mdg View Post
    Evening.
    As long as you do nothing more than think about it, then you are automatically ahead.
    Nov 2018
    UNITED KINGDOM
    Sorry for the slow reply.
    The scales are clean and to be fine when swapped the one working reader head into both scales.
    I found the of the pea bulbs to have been blown and struggled to fine the correct replacement so used the bulb from the X axis as it was working.
    IV tryed to adjust the lens but have had no success with getting any readings on the dro even when swapping the leads at the rear if the display (incase the display was faulty also).
    Has anyone got a link to the type and wattage of the bulbs also how to set up the lens.
    I would like to keep the machine original as just got it.
    Thanks for any help
    Sep 2002
    People's Republic
    4,385
    420
    2670
    I thought there was a thread here about it but could be imagining it
    Worth calling your local heidenhain rep, they may not fix old scales but might have the info
    May 2005
    Central Fla. USA
    186
    13
    Jul 2010
    Rochester, NY USA
    2,242
    10
    527
    Try these guys:
    Products @ A Tech Authority
    Bill
