Bridgeport J head collet question
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
    Dec 2017
    Rhode Island
    204
    8
    Default Bridgeport J head collet question
    Hi All, just a quick question, just purchased a Bridgeport with J Head, and it came with a bunch of R8 collets. Is that the only size these are made to accept, or are there other spindles that were optioned like on my SB heavy 10.
    If so, is R8 considered the "good" size?
    Aug 2012
    California, Central Coast
    4,260
    2256
    1684
    If by good you mean common and easy to get then yes it is the good one. At some point they had other spindles.
  3. Likes texasgunsmith liked this post
    Dec 2017
    Rhode Island
    204
    8
    I did just find this discussion, which describes the R8 as common but a weakness is that it's tool holding is only at the base and the grip is not as good on larger tools. Just wondering how this falls in context, how really important or not is the weakness of R8.
    LINK:
    R8 vs others
    Virginia
    30,566
    7561
    9538
    Quote Originally Posted by FlyinChip View Post
    ..how really important or not is the weakness of R8.
    Since you have already BOUGHT a BeePee WITH R8?
    The only thing "important" NOW is getting comfortable with its limitations [1] so you don't have avoidable problems. About sebenty-leben-brazilian folk have had to do this already. You can do it, too.
    You cannot CHANGE this as easily on a BeePee as putting better wheels, tires, or brakes on a motor vehicle.
    Learn to live with it.
    Or trade it for a mill with a better spindle taper.
    40-taper is a "sweet spot" for a balance between affordable tooling and proper grip and power transfer. 30-taper is not as common, goods often cost MORE than 40-taper as there is less out there in the used-but-good market, and fewer "economy" makers of new.
    All that's for "next time"... when you do your research BEFORE you make the purchase, yah?
    [1] Basically, it's a piece of s**t, but a cheap and common POS everybody just USES without much discussion. Sorta like toilet-paper in public washrooms. Most ANYTHING is better than an empty roll, yah?
    Dec 2017
    Rhode Island
    204
    8
    I learned on a BP and I'm sure I'll be happy with it. That being said, need to learn about the machine and this is part of it.
    How much of an end mill can I use on steel and depth of cut? For example, at school, on bigger BP's I used 2.5" shell mills and cant recall but took pretty substantial cuts.
    I read on here that with an R8 setup, I should be thinking about 3/4" end mill as a max, which sounds kind of small.
    So for anybody reading this, in realistic terms, if this is an average condition BP J-head with the R8 setup, milling steel, how big of an end mill and how deep of a cut would be the maximum, approximately?
    Virginia
    30,566
    7561
    9538
    I thot it was 3/8", not 3/4"? My smallest are B&S #9, about double an R-8's limits. I don't have to push even that above a 3" shell or face mill, nor a 1" endmill. The 40-taper is there for heavier work.
    The idea, of course, when YOU OWN a mill, is to preserve the mill by respecting its limits so you can use it on the next task, not trash it pushing beyond its limits. I don't mean fear it or baby it. Just use the maker's published limits, not what Bubba "got way with.."
    "School" mill or "company mill" you don't have to pay for or live with, the idea is to get to the end, even if you DO trash the mill.
    There are TONS of things an R-8 can do all-day, every-day for YEARS.
    Smaller diameter cutter can make just as big a cavity. It's a mill, after all. Not a drillpress or a grommet-punch. It has infrastructure. Traverse. Rotabs, even.
    That takes more passes, usually more time - sometimes not. But all of it at lower stress.
    Dec 2017
    Rhode Island
    204
    8
    so.... how big an end mill can turn on steel with R8 typically?
  9. #8
    Sep 2009
    Apex, NC
    1,521
    753
    As Bill alluded to, depends on the endmill, and how much you want to torture the spindle and machine. Get some good new, or new condition Hardinge r-8 collets (not many are needed for standard end-mills). Keep the tool projection as short as practical for the job (this means usually using an R-8 collet only (not a tool-holder or collet adapter)). My opinion is about 1/2 3+ flute carbide endmill on steel for fullish depth of cut on a standard short length endmill (maybe less for a full-width slotting cut), and reasonable stepover. Bigger end-mills can be used but you just reduce the depth of cut. I use an Iscar f-45 2.5" face-mill (5 polished positive rake inserts), for facing, this will allow .1" doc in aluminum, only about .04 max in steel. I have no problem with R-8's slipping using the above, -they provide the shortest tool length, and best runout. 3/4 is the maximum dia shank r-8's were designed for (those "stepped" r8 collets larger are worthless). It's a light machine, and it's advantage is versatility and decent accuracy when used within it's limits, high material removal rate is not it's forte' and it is slooow for that purpose. The R-8 collet isn't really the limiting factor itself, it's the overall spindle size and general rigidity, and the R8 system is perfectly adequate for the machine's capabilities (in other words, sticking a larger/different tool-holding system on it will not increase it's capability).
  10. Likes Stradbash liked this post
  11. #9
    Virginia
    30,566
    7561
    9538
    As big as you can find room to swing with the dovetail-ram clear out without hitting the column ways. Want's a reduced shank, mind.
    Now.. would you care to actually REMOVE any of that steel? "Take a cut". "mill it".
    You ain't out of the woods, yet Pilgrim.
    I can put a very basic one-inch thick by four-inch square slab of the most ordinary LOOKING steel you've ever seen into your hands, watch you clamp it in the vise, tool up and ...
    ... stand aside, watch...and laugh my ass off because.. you wont be able to mill it AT ALL.
    Steel. Not Osmium.
    Mind... it might have a bit of Manganese in it, but y'know.. alloy, schamalloy.. still mostly ignorant Iron, why would the small shit matter?
    I don't think you PLAN to "troll", but to a mill hand, the question put only as "how big" means we cannot communicate.
    There isn't enough information in the question to look for an answer.
    What yah should do is get a job with Durex as a condom sales rep to 7-Eleven and Circle-K.
    Where "size matters".
  12. #10
    Nov 2007
    E-burg MD USA
    581
    97
    Flyin Chip, Sir
    R8 is "common" because it works. With that said.. 'R8' is a style of collet and a way to designate said stye of collet. There are literally hundreds of different tools made that 'fit' a r8 spindle. Do yourself a favor and look up r8 weldon tool holders.. no 'slippage' there... I think you are to ignorant of milling/machining to know what your really trying to ask. ( This is not a slam, just an observation)
    Go forth and edumacate your self on speeds and feeds and such.. such knowledge will be applicable to all other machining problems/needs you may come across. (K.H.Moltrecht's tome "machine shop practice vol 2 would be a great start along with a copy of the machinery handbook )
    What I believe you are trying to ask is "how much metal can I remove with a tool in one pass with a BP ?" and the answer is "it depends".. Lots of variables as Thermite eludes to in his own way... Really it all boils down to the eternal quest of man for horsepower and the more the better.. So go forth and educate yourself on speeds and feeds and HP calculations and you will find your answers.. Also trial and error can be a good guide also..
    Hope you find this helpful
    Stay safe
    Calvin B
    PS Just in case it helps in any way I do most of my milling on my little knee mill will a 1/2 inch end mill held by a r8 weldon style tool holder
  13. #11
    Aug 2006
    N.W. Ark.
    411
    241
    71
    Chip your missing the whole point, your working on a piece an emergency the line is down, there breathing down your neck WERE LOOSING MONEY,WERE LOOSING MONEY.
    so your I'll just speed up the feed good ol BP cuts right into it cuts to good and when you take the piece out sob the damn cut is 200 thou to deep because of the DAMN collet wouldn't hold the bit is ok the BP would spin but the DAMN collet would not hold... both my mills have bxs 7 and bxs 9 never had that problem again
  14. #12
    Virginia
    30,566
    7561
    9538
    Quote Originally Posted by batw View Post
    To be fair, he didn't say R-8 COLLET.
    Even so.. a Weldon side-lock in MT or B&S taper has a long precision-ground "in bearing" fit to transfer power AND resist side-force.
    A side-lock holder in an R-8 has only the shorter closing taper at its nose in "bearing" contact for transfer of driving force. The long tail doesn't much help with EITHER driving force or resistance to side force - it's a slip fit, not a ground "bearing" fit.
    The R8 may suit the need if not abused. It will still wear faster than the long tapers.
    Take three equally old, equally hard-done-by mills? The MT and B&S will need de-burred. They will have been used seldom with collets, and their collets bear longer against the spindle taper even with relieved center of span and an internal grip a good deal shorter on the tooling.
    The R8 will need REGROUND. It will have seen "too many" collets, had to deal with slip and side-to-side rocking, may even see some "lobed" effect, same as hard-worked 5C and such. All the wear, all possible sources, is concentrated into a much smaller area.
    The only genuine plus is that an R-8 is far, far, less likely to get "stuck" in a hot spindle than a B&S taper.
    MT doesn't belong on a mill to begin with, but that war was over and done with more than a hundred years back, so mostly, it ain't.
  15. Likes calvin b liked this post
  16. #13
    Sep 2006
    Sacramento County, California
    3,928
    2458
    1393
    It's possible to swap spindles on your BP to something like a 40 taper. However, to take full advantage of that size, you would need more horsepower than the typical BP.
    Used within its limits, the R8 is perfectly fine for a typical BP.
  17. #14
    Virginia
    30,566
    7561
    9538
    Quote Originally Posted by Newman109 View Post
    ..and rather a lot of other changes, few, if any, that are practical or even CLOSE to "economic". As with s**t, the stresses "flow down hill" to the next point yah just over-stressed.
    South Asia, motor-scooters grew into 3-wheeled banana-haulers and taxi-buses. While they had no better options. See also "Iron water buffalo":
    Thailand's Iron Buffalo in action, Its rice planting season. - YouTube
    Mostly, we DO have better options than "tuk-tuk"ing of lightweight milling-machines.
    So - if one actually NEEDS such? Don't abuse the R8 BirdPort. Leave it undamaged for he who can live with that.
    Go find a stronger-EVERYWHERE mill for those greater challenges - even if only a later, stouter, BP.
  18. #15
    Dec 2017
    Rhode Island
    204
    8
    OK thank you. I think I get it although one post suggests not using a tool holder for an end mill, other post does. I have a bunch of R8 collets that came with the machine. Before I started asking questions I would simply have used on for holding an end mill and going to work. And I still will, but I'd like to get a consensus on using a tool holder and how that works vs just holding the tool in a collet...
  19. #16
    Sep 2009
    Phoenix,AZ
    1,853
    2849
    477
    If you are afraid of end mills pulling out of the R-8 collet get a few [ie 1.2-5/8-3/4] Weldon side locking end mill holders. Use these where you are taking the biggest cuts the old BP can handle,normal usage use the R-8s and don't lose sleep over the holding abilities of the R-8. Over thinking this for the most part I think!!
  20. #17
    Virginia
    30,566
    7561
    9538
    B&S #9, as said, has roughly DOUBLE the grip and HP transfer of R8.
    For two mills with B&S 9 spindles, I have one full set of brand-new B&S 9 collets. But only because B&S has gone scarce. They've never left their wrappers. They will probably ALL still be in their wrappers when I die.
    I have side-locks. Lots of them. My PDQ-Marlin VS and S are also side-locks.
    IF.. I had a 5K, 10K or 20K RPM CNC spindle to tool? THEN I'd want a milling chuck or shrink holder because.. only up at those challenging speeds does the very minor clamping offset of a Weldon side-lock's screw actually matter to a mill. Needless to say, it would not be R8, either. Capto, probably.
    Down in the "manual" world, a mill doesn't ordinarily mount a no-flutes item like diamond wheel. Cutters have teeth or flutes. Each one is already a form of "interrupted cut" as it is rotated into the cut on material that is also moving, relative to its axis.
    Low/no TIR does bring better tool life. But really.. its a mill. Not a balance staff in a fine Swiss watch. You can't make all the other movements go away and still do useful work, anyhow. There WILL BE imbalanced side-forces at work. Or it is not a mill, it's an "only direction is DOWN!" drill press.
    Eschewing side-locks is just not helpful. Those should become your go-to for routine milling, especially if you could "only have one".
    Better to HAVE both "available", of course. I do have ER and TG and Gorton collets -even "native" 40-taper collets for the mills.
    2CW
  21. #18
    Sep 2009
    Apex, NC
    1,521
    753
    I respectfully disagree, that on an R-8 spindle, that if one wants the best tolerances and finish without more haranguing, that extra 1+ inch projection required for side-lock holders makes a noticeable difference in rigidity in the flexy R-8 system and bearings. (notwithstanding more runout and extra clearance needed). Of course, this is with a good-condition r-8 quality collet and good-condition spindle bore and bearings comparison.
  22. Likes Oldwrench, JRIowa liked this post
  23. #19
    Virginia
    30,566
    7561
    9538
    Quote Originally Posted by car2 View Post
    You are simply blaming BOTH the side-lock AND the R8 for circumstances beyond the control of either one.
    The degrees of freedom and flexibility a BeePee delivers come at the price of .. too MUCH "flexibility" when it is NOT wanted.
    Your reduced stick-out just shortens the lever-arm that was over-stressing that limited rigidity. A machine-specific "band aid", if you will.
    Even a mere R8 is not restricted to a BeePee. Heavier mills have offered R8 as optional. Many are not as flexible, and routinely manage not only close-coupled side-locks, but also extended "hang out" side-locks, so as to get down inside places where that is needed.
    And "of course" extra finesse is required with greater stick-out. Any mill. Any spindle system.
  24. #20
    Sep 2009
    Apex, NC
    1,521
    753
    That was specifically my point, that reducing the stickout improves the inherent limited rigidity of a BP by reducing the moment, so why not take advantage of it. I don't see any advantage to tool-holders, still have to change the r8 (and sometimes with a regular collet, you DON'T need to remove the collet, just the tool), and you can't really use the r8 toolholder with tool for precision tool changing and expect the same z-height (not that there's a convenient way to do that on a manual mill anyhow), and if it's for "convenience" of having multiple tools, a bunch of holders are required (still have to change them)). To each his own...I'll take the improved rigidity and accuracy of a good r-8 collet and shortest practical tool in it that'll do the job... Cheers
    (one reason folks seem to use toolholders is that they have had tools slip, or think they will. In that case, they probably have bad collets, bad spindle, and/or over-taxing the machine anyhow).
