The title is the question; on J-head the step pulley RPM high-speeds are 660/1115/1750/2720 RPM values, but the motor plate gives ratings for values both at 50hz and 60hz. While I've heard it talked about a lot around here with the presumption being these step pulley speeds are for 60hz, I've never actually seen anything which confirms they are for 60hz. So I would just like to pose the question to alleviate my concerns that I'm calculating VFD-produced RPM values correctly. Are the J-head pulley speeds on the front plate indeed for 60hz operation? Thanks!
