Bridgeport M head motor pulley
Likes Likes:  0
Results 1 to 6 of 6
    Apr 2019
    Georgia
    12
    Default Bridgeport M head motor pulley
    Recently purchased a Bridgeport mill with a "M" head that is missing the motor and pulley. I called Hardinge and was quoted almost $1000 for the motor. Not really in my budget, but couldn't pass up a machine in very good condition otherwise for $500.
    I'm going to build a adapter plate and mount a face mount motor to the original mount. Next problem is the pulley. I know I can buy a new one for $250, but I need the practice so I figured I would make my own.
    Are the motor and drive pulleys the same size, just flipped over?
    If not, where can I find the diameters for the motor pulley?
    Jul 2007
    UNITED KINGDOM
    5,215
    3127
    2641
    I won't guarantee it for the Bridgeports, but most step pulleys of this type are the same sizes but flipped over. Subject to shaft size, any needed clearances for bearings etc.
    Dec 2017
    New York
    176
    29
    66
    They would need to be the same size or the belt wouldn't fit properly for the different steps.
    Ted
    Jul 2007
    UNITED KINGDOM
    5,215
    3127
    2641
    Actually, they don't. The diameters of the matching steps on each pulley need to be sized so that the belt length is the same for each speed, but the pulleys don't need to be identical. I have made a replacement set of poly-V pulleys for my Beaver VBRP to give it the same lowest speed and a higher top speed than the original V belt pulleys. This means that the two pulleys are not the same any more.
    Dec 2017
    New York
    176
    29
    66
    Yes, I do agree with that. You are correct. I over simplified.
    Ted
    Sep 2004
    Fort Worth, Texas
    2,224
    301
    198
    I have an extra motor pulley. Two largest grooves have some damage, but could probably be fixed easier than making from scratch. PM me if interested.
