Bridgeport M head Spindle spline repair
Results 1 to 16 of 16
    Dec 2018
    Virginia
    5
    Default Bridgeport M head Spindle spline repair
    Guys,Can someone give me a measurement from nose to threaded end of m head spindle. A drawing would be great but beggers cant be too choosey. I am going to attempt to make a new spindle out of 4140. my shaft mics up fine with the exception of several inches broken of of the splined end. bought this little M head with thoughts of adding to my Diamond m-24 horizontal mill. As always Thanks,Blaine
  2. Likes M.B. Naegle liked this post
  3. #2
    Jun 2005
    Virginia
    1,183
    124
    188
    I measured an M head I have and made a drawing for you. I included the spline as best I could measure. To me it looks like a straight side spline. But on the one I measured, one side of the spline is slightly wider than the other - due to wear? I doubt they would machine it off center?? On another M head it looks like the sides are both the same width.
    Irby
    Last edited by IrbyJones; 06-25-2019 at 11:35 PM. Reason: added possible cutter to drawing
    Jun 2005
    Virginia
    1,183
    124
    188
    Did you want measurement of the entire spindle? You have the spindle, so I figured you just needed the threaded part that was broken off.
    Irby
    Dec 2018
    Virginia
    5
    Irby, Thanks for the reply. I don't know exactly how much is broken off and that's why I needed the full length measurement. Thanks Blaine
    Jun 2005
    Virginia
    1,183
    124
    188
    More on the spline itself. I don't know anything about splines so I looked some up and found out this -
    There's a thread on this forum about cutting straight sided splines that should help you if you make or repair your spindle:
    6 Tooth Spline Shaft
    Rudd, on post #10 links to a pdf (http://ashgear.com/pdfs/f6.pdf) that lists cutters and one in particular (F6-087C) seems to be the one to cut this spline you need. BUT I wouldn't recommend using it. Using a cutter like that sets the width of the spline tooth itself by the depth of the cut. That's probably not the way you want to set the spine tooth width easily. In the thread above they suggest using an end mill in a vertical mill or a milling cutter like in post #13 in a horizontal mill to cut the spline teeth. You can set the teeth width more exactly that way. The valley between the teeth will not be correct when the teeth are cut that way, so you need to go back and cut it down some way, any way you choose. The way shown in post #13 is great if you have a horizontal mill, or an end mill small enough to fit between the teeth is fine if you just have a vertical mill. Overall that thread is great about telling you how to cut the spline!
    Here's a picture of my M head spindle and the mating drive pulley center part. You can see that the space between the spindle spline teeth has a clearance with the drive pulley part, so whatever you do to cut that space between the spline teeth is not critical. The spindle has a radius there as though a cutter like F6-087C was used, but that isn't critical. It could just as well be flat.
    Irby
    Jun 2005
    Virginia
    1,183
    124
    188
    Just for the heck of it, here's an updated drawing that shows the curved ID of the spline (which is like the spindle has), where the last drawing I did had it flat.
    Irby
  8. Likes alum100k, memphisjed liked this post
  9. #7
    Jun 2005
    Virginia
    1,183
    124
    188
    I forgot to extend the spline through the threaded section at the end of the spindle on my previous drawings, heck. Here's a corrected drawing. Now I'm done.
    Irby
  10. Likes memphisjed liked this post
  11. #8
    Jan 2019
    Virginia
    135
    50
    30
    Quote Originally Posted by IrbyJones View Post
    Irby
    Wow!Irby. This is super helpful information as reading a blueprint. It addresses the specific need.
  12. #9
    Dec 2018
    Virginia
    5
    Thanks Irby for your help. It's people like you make this forum.
  13. #10
    Apr 2018
    UNITED KINGDOM
    2,039
    948
    Well, maybe one more time
    Splines don't have an i.d. and an o.d., they have major diameter and minor diameter. They can fit on the major diameter, the minor diameter, or on the side. But you don't want to make them fit on two of the features, just one.
    In general, straight-sided splines are a major diameter fit. That's because grinding the o.d. of the mating shaft is easiest. If it's a minor diameter fit you can often tell because the roots of the male splines will be ground. As you can imagine, that's a lot more trouble and a lot more expensive so you don't see it often.
    Side fit is usually for a permanent fit and you don't see it much.
    For a sliding fit, there is class A, B and C. Basically that's just the amount of looseness.
    Looking at the numbers here, I'm going to go out on a limb and say this is a loose major diameter fit on the .872 feature. That would follow normal practice. That would make the major diameter of the female spline about .875.
    My criticism would be, your print has a .001" fit on the minor diameter. I do not think this is what Bridgeport intended and you could end up with the dimensions fighting each other. I don't have spline fit info handy but I'd make that minor diameter a good .015-.025" clearance. Maybe more, because unless they used an undercutting cutter on the spline, then the corners will have a radius and your pulley could hang up on the shaft. If you want to make it strong (why ? I guess it's a fixation with me !) just make that a nice radius. The smaller diameter on the shaft doesn't matter as much as the sharp corners do for life expectancy. Within reason, of course.
  14. Likes memphisjed liked this post
  15. #11
    Jan 2019
    Virginia
    135
    50
    30
    Quote Originally Posted by EmanuelGoldstein View Post
    This is very revealing information. I do appreciate the knowledge and time to share it.
  16. #12
    Dec 2018
    Virginia
    5
    With a lot of help from you on this forum I am getting ready to machine this M head spindle. I have one more question before starting and is should I cut the 7/8-20 LH. threads On the end of the spindle first and then the splines or cut the splines first then the threads? Again Thanks for all your help.
  17. #13
    Jul 2001
    North Carolina
    1,939
    166
    387
    Emanuel-
    Not sure why you are passing criticism on Irby's drawing.
    His dimensions appear to report sizes of an actual specimen.
    He makes no notation of tolerance or fit.
    It is not far to criticize something that was not in the vision
    of what was in your mind. Irby was not providing engineering data,
    and never represented as such.
    But thank you for adding your knowledge of fits and tolerance.
    I am sure it will be most helpful for anyone trying to replicate
    the spindle.
    --Doozer
  18. Likes alum100k liked this post
  19. #14
    Jan 2019
    Virginia
    135
    50
    30
    Right! I liked it all as many experienced Irby's clear measurements and the cutting wheel profile. I would thread the end first and then machine the slots. They go right up into the threads but these can be dressed instead of interrupted thread cutting.
  20. #15
    Apr 2018
    UNITED KINGDOM
    2,039
    948
    Quote Originally Posted by Doozer View Post
    Emanuel-
    Because it was incorrect. And I didn't criticize him as a person, I tried to explain how splines fit.
    If you make something wrong but can't handle any corrections, then I feel sorry for you. Are you a millennial, by any chance ?
  21. #16
    Jan 2019
    Virginia
    135
    50
    30
    So then, you would thread the end first. That's the easy part. Your concise explanation of fit is similar to how gears are supposed to fit but it is different. Sliding surfaces and such call for what you posted.
