Bridgeport mill quill lock problem
Results 1 to 14 of 14
    Jan 2016
    Wisconsin
    11
    Default Bridgeport mill quill lock problem
    Good day
    I recently saw a video where the guy used a different approach to stop the quill lock from tightening itself, but now of course I cant find it. he remade the shaft and the rear threaded brass shoe and threaded the shaft and shoe using left hand threads which reversed the direction of locking from clockwise to counterclockwise. Has anyone done this or heard of this being done?
    Ray
    Nov 2014
    Florida
    3,730
    1539
    1764
    Quote Originally Posted by 1mondo View Post
    Good day
    Ray
    Don't know about that, but you should be able to adjust the handle so it is not putting pressure on the mechanism ie -adjust it so it is loose, then re-position handle so it is hanging straight down? Maybe I am misunderstanding what you want?
    Jan 2014
    Temecula, Ca
    2,850
    1278
    3682
    I just use a rubber band
    Oct 2010
    Dewees Texas
    2,351
    27
    633
    On my Lagun and bed mill I just pulled the units out and installed them so the handles are in the back of the quill casting. Gravity is on my side now and the handle is out of my way.
    I do not think this is a new solution.
  5. Likes Rob F., Illinoyance liked this post
    Dec 2013
    New Hampshire
    145
    48
    73
    I use a small neodymium magnet on the head that holds the lock handle tip in the up position
    May 2010
    NY, USA
    54
    10
    Quote Originally Posted by jmanatee View Post
    Same here - works well.
    Nov 2007
    Ohio, USA
    96
    17
    O-ring groove and small o-ring on the locking shaft. Provides enough friction to hold the little handle up.
  9. #8
    Nov 2007
    marysville ohio
    9,358
    2668
    6184
    I just put a spring on the threaded shaft that pushes the clamp blocks apart. This holds the handle wherever you put it and spreads the lock blocks so they don't drag on the quill.
  10. #9
    Dec 2005
    Wisconsin
    893
    11
    124
    My rubber bands deteriorated fast. Tried reversing the blocks with the handle in the back. It was odd and the other guys didn't like it, so I put a magnet on.
    Dave
  11. #10
    Mar 2018
    Kansas
    168
    106
    34
    I've considered some solutions to the drifting quill lock.
    Seems to me the rooster magnet (aka "cock-up) works well enough, but attracts undesirable elements in exchange (i.e. chips)
    I've heard of threading the shoe and shaft left-handed. That would seem a good solution I suppose.
    For my part, a little friction is all that's needed, like a spring between the two shoes, or perhaps an Oring.
    I ended up buying a couple new shoes w/ a spring in between off Fleabay. I normally don't like buying Chinese stuff, but it was a small item and super cheap. Plus I liked the longer handle. I think it cost me something like 13 bucks.
    I haven't put it in yet because I've been too busy with other things, but here is a pic.
  12. #11
    May 2010
    NY, USA
    54
    10
    I have had the magnet on for years and there are only a few chips bigger than dust. If it ever became a problem, it would not be hard to clean
  13. #12
    Mar 2018
    Kansas
    168
    106
    34
    Good to know.
    Here's on other idea I haven't seen. It uses a little weight to counter balance the lever.
    It's on the end of the thread. Also is a link in the thread for how somebody machined their own lever and shoes, although he used right handed threads.
    Aftermarket Parts for Sharp LMV
  14. #13
    Mar 2009
    5,041
    91
    922
    Quote Originally Posted by Randalthor View Post
    That's fine if you are starting from scratch.
    With the stock shoes the inside holes are too large and a correctly sized spring will rub on the spindle introducing a new wear pattern.
    And the wear will be created by a steel part rubbing on the spindle, not the brass shoes. I suspect that the diameter of the thread in the
    picture is less than the stock diameter of the thread.
  15. #14
    Mar 2018
    Kansas
    168
    106
    34
    Quote Originally Posted by rons View Post
    Rons,
    You wrote about a wear pattern on the spindle. I assume you mean quill?
    If so, I hadn't heard of the spring wearing on the quill, but could see that as a possibility. The shoes are drilled off-center to move the tensioning bolt away from the quill, but maybe that's not enough with a spring around the bolt. I'll look for that when I install the new shoe assembly on mine. Thanks for the heads up.
    If the spring does rub on the quill, I'll just make new shoes when I get time.
