BridgePort to Pc Connection
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Apr 2020
    UNITED KINGDOM
    18
    Default BridgePort to Pc Connection
    Hi this has probably been asked before but can someone help me with connecting my BP series 1 MKll to my pc which the OS is windows XP Pro 64bit when i try to send from the Mill it says (EXT IN-/OUTPUT NOT READY.
    Any help would be greatly appreciated .
    Sep 2002
    People's Republic
    4,461
    434
    2711
    You need to list the control to get help
    It is a Heidenhain
    Do you have a serial port or a USB emulator
    Do you have remontpc? It has to be on and ready to send or receive before pushing the button on the machine
    I have successfully run a cheap emulator on a little XP notebook. I have the emulator, adapter 9-25 pin, connection box with jumpers[I believe it is 'null modem' and may not actually be required] then 25 pin cable
    Apr 2020
    UNITED KINGDOM
    18
    Cheers for the reply
    It is a Heidenhain YES IT IS A 150.
    Do you have a serial port YES IT IS A SERIAL PORT.
    Do you have remontpc NOT SURE WHAT THIS IS.
    I have a 25pin to 9 pin adapter then a 9 pin serial cable
    and i run Hyperterminal.
    hope this is a bit more help.
    Sep 2002
    People's Republic
    4,461
    434
    2711
    Quote Originally Posted by gixer View Post
    Then either download remontpc from heidenhain website or get the settings correct in hyperterminal
    from memory, someone help me out....
    2400 baud, 1 stop bit, even parity, no flow control
    Aug 2019
    118
    15
    17
    Baud, stp, parity... that brings back a lot of memories trying to hook up anything to an older computer.
    Mar 2009
    5,602
    103
    1084
    Windows XP-64 is a free version which was not supported.
    Is this the location for that "remontpc" software?
    PC software and manuals
    Apr 2020
    UNITED KINGDOM
    18
    I`ve changed now to windows 10 and installed TNCremon which puts up an error no responce from TNC so i think it might be the cable so i`ll sort another cable and try that.
    Sep 2002
    People's Republic
    4,461
    434
    2711
    fire up tncremo
    start tncserver within it
    change the settings so that the baud rate is correct
    connect the cable if it isnt
    write a little program in the machine
    set the software to receive and start
    try to send the program
    Apr 2020
    UNITED KINGDOM
    18
    Hi i`ve tried different options and still can`t get them to communicate with each other is there a certain pin out on the serial cable it shows a few different types in the Tnc software would anyone know which is the correct one for the TNC150 cheers.
    Apr 2020
    UNITED KINGDOM
    18
    I`ve checked my cable and that seems to be ok if i try to establish connection it comes up with No Response from TNC is there anyway i can check the serial at the Tnc.
  11. #11
    May 2009
    San Jose, CA
    198
    274
    236
    In the old days, with 25 pin RS232 connectors (PC serial data), there were handshaking lines RTS and CTS, and possibly another (memory shorting out...). In more recent times, the communications chips became more sophisticated and these lines are generally not necessary. It is standard practice these days to only have 3 lines connected between the serial ports: a Ground wire, A Data IN wire, and a Data OUT wire. If you hook up an old device to a modern computer, the computer may not be using the old handshaking lines by default, while the external device may require them. A cable between the device and the computer may have the lines connected to the pins, but if the handshaking protocols are necessary but not enabled, then the external device will not be able to respond.
    What I am describing is a generic issue for serial communications. I have no direct knowledge if this applies to your situation, but if the Heidenhain box is old, it very well might. If you can find a manual for the Heidenhain box there is a chance that it will show the serial port output terminals. If so, check if RTS, CTS, and any other handshaking lines are mentioned. If they ARE, you may have to find a way to enable them on the PC that you are using to communicate with it.
    Hope it helps. Best wishes,
    Michael
  12. Likes Scottl liked this post
  13. #12
    Apr 2020
    UNITED KINGDOM
    18
    OK cheers i`ll have to look into it i use to do a lot with serial over 25 years ago but can`t really remember much of it now.
  14. #13
    Apr 2020
    UNITED KINGDOM
    18
    Is it possible the software for the tnc has got corrupt as it just keeps saying EXT IN-/OUTPUT NOT READY i tried a loopback test and that was the same result.
  15. #14
    Apr 2020
    UNITED KINGDOM
    18
    Hi iv`e finally got the PC communicating with the TNC 150 the problem i have now is when i send a program from the pc to the TNC nothing appears on the TNC screen but if i send a program from the TNC to the PC it sends ok and saves it to the PC any help would be appreciated .All so does anyone know how to setup the drip feed.
    Cheers
  16. #15
    Sep 2002
    People's Republic
    4,461
    434
    2711
    Ok, so you know your baud rate etc is correct
    What program did you end up using?
    If it is TNCremot and it is just hanging, try different import routines.
    read in program offered or read in all programs
    there is a certain order of doing things that is not obvious but which makes a difference
    also send the program you just exported to make sure it is a good program
  17. #16
    Apr 2020
    UNITED KINGDOM
    18
    OK i think i`ve sorted it now i can upload and download all the programs i have in the TNC.The program i was trying to upload was in the wrong code i think, can i convert programs i do with fusion 360 to upload to the TNC.
    Cheers for your help so far.
  18. #17
    Apr 2020
    UNITED KINGDOM
    18
    OK so i have another problem now.I can download & upload programs that are on my mill But i can`t upload any programs i make on fusion360 i`ve tried different versions of HeidenHain if i do it in ISO i can see it uploading from the PC server but thats it nothing on the mills TNC if i try it in another format eg (.i .h )i don`t see anything appear it just shows <ETX> on the server screen.Anyone got any ideas.
  19. #18
    Apr 2020
    UNITED KINGDOM
    18
    I`ve found out with some digging i can`t Dripfeed on my Tnc 150b because my parameters only go upto MP214 is there anyway i can upgrade the eprom to another version to accept drip feed.
  20. #19
    Sep 2002
    People's Republic
    4,461
    434
    2711
    Post the beginning of the program from fusion
    I had to rip a bunch out of the post to make it load in my 151
  21. #20
    Sep 2002
    People's Republic
    4,461
    434
    2711
    pgm name needs to be numbers only
    no block form
    machine needs to be set for ISO if ISO pgm IIRC
    R
