Good afternoon.
I am new here, and have found myself looking for an answer. I have fully rebuilt several Series 1 BP variable speed head machines and have had fantastic outcomes. Currently I am working on a machine for myself and wondering if anybody might have a good answer.
While replacing the Bearing in the Brake Bearing Cap, the old bearing came out much easier then I have ever experienced. Simply pushed all the way out with my fingers.
I clean up the brake bearing cap good, notice nothing out of the ordinary. No minor cracks, no heat marks or anything that looks suspicious. I check the roundness of the brake bearing cap, also fine.
My new bearing also just slides right in. Should be a press fit.
I do not want to put this all back together and then decide......I should have replaced that brake bearing cap.
Before I do replace that brake bearing cap, has anybody else had this issue, without visibly being able to spot or see any cracks or anything that would lead to this diameter being slightly big?
Thanks Jason
Thanks Jason
