Bridgeport Series 2 Riser Dimensions?
Results 1 to 7 of 7
    Jan 2003
    Imlay City, Michigan
    2,039
    105
    223
    Default Bridgeport Series 2 Riser Dimensions?
    I have riser that I believe is for a Bridgeport Series 2?
    I don’t have a machine that I can measure the bolt pattern.....anyone have a picture or dimensions of the series 2 bolt pattern?
    Another question, does the 4 hp. Series 2 and the series 2 special share the same bolt pattern for the turret?
    I looked online and haven’t been able to come up with anything!
    Any help would be appreciated!
    Kevin
    Dec 2013
    Fort Wayne, IN
    772
    816
    273
    Yes, the bolt hole pattern for a Series II and Series II Special are the same. The turret on a Series II Special is different from a Series I turret, but the II and II Spacial have the same pattern.
    Jon
    Jan 2003
    2,039
    105
    223
    Quote Originally Posted by HWElecRepair View Post
    Jon
    Thanks Jon!
    Do you happen to have any dimensions or pictures/literature to help identify this riser?
    I will post pictures later, will see if that helps with the identification?
    Kevin
    Dec 2005
    UTAH
    568
    85
    58
    I have two Series II Specials here that have 6" risers. Since the risers are on the machines it's difficult to get measurements without removing them. But from what I can measure the 5/8 dia. bolt holes appear to be 9.25 between centers front to back and about 10.25 right to left. If time permits in a few days I may try to remove one to get a detailed layout of one if you still need it by then. The spider is code number 2-15-0008 according to the manual.
  5. Likes HWElecRepair liked this post
    Jan 2003
    2,039
    105
    223
    Quote Originally Posted by moldcore View Post
    That’s great info!
    Thanks for the offer, but don’t bother taking the turret off, if you could take a measurement of the circumference of the riser, I think that would be all I need!
    Thanks again everyone!
    Kevin
    Dec 2005
    UTAH
    568
    85
    58
    Looks like 55" on the circumference. Also it looks like I may be off on the holes a bit. If you need those I can recheck tomorrow.
    Jan 2003
    2,039
    105
    223
    Thanks for the dimensions, the diameter matches, 17.5 and the bolt pattern matches what I have!
    Looks like this is in fact a Series II riser!
    Thanks again!
    Kevin
