Bridgeport series I collet not locking
Results 1 to 5 of 5
    Apr 2019
    Ohio
    Default Bridgeport series I collet not locking
    Good morning all,
    I have a post 1977 2hp Bridgeport brand series 1.
    It has new brakes, and they will stop the spindle cold when I turn the unit off, so no problem there.
    However, the brake will not hold the spindle while I try to loosen the drawbar to release or tighten a collet.
    The good news, I currently have no collet in the machine, so I'm not stuck, but of course, without a collet in the machine, It's a really pretty sculpture with no real use.
    Any ideas?
    Jun 2013
    Northern Il
    1,171
    651
    1148
    Is the drawbar okay. Sounds to me like the threads are messed up.
    Also,were you possibly over torquing the drawbar. You want it tight but not insanely tight.
    Sep 2007
    Northern Illinois
    2,895
    1604
    1728
    When the brake won't hold against turning the drawbar, shift the speed range into low. Much more resistance with the back gear engaged.
    Dennis
  4. Likes Paolo_MD liked this post
    Apr 2019
    Ohio
    Quote Originally Posted by Ziggy2 View Post
    Drawbar looks perfectly fine.
    Then I swapped it for a spare I had.
    Works great now.
    Thanks!
    Dec 2017
    New York
    116
    21
    45
    Keep in mind that if you have the spindle in neutral the brake will not hold at all. It has to be in either Hi or Low range.
    Just a note,
    Ted
