OldSpaghettiMike
- Nov 1, 2018
Hello, everyone,
My name is Marc and I am a first time poster here. I'll get straight to the point.
I have been working on a Bridgeport Series I Mill (manuf. in 2000) with a 2J head for the last ~2 years. I do not own it, but attend an engineering college where it is housed. The mill has always turned out good parts (when a competent operator is using it of course ). However, recently, it has been doing something rather strange.
If I move the knee up or down, I will lose my location in the x-axis. For example, I will touch off an edge, set a zero, move over the radius of the edge finder, re-set my zero, and then will drop the knee to mount a drill chuck. When I drop the spindle with a bit in the chuck to check my location, it'll be offset from the edge by up to 1.5 inches!
This happens regardless of the table being locked or not. I do not believe it is an issue with the x-axis gib being worn, as I maintain stability in this direction while taking heavy cuts in either the X or Y direction (even while climb milling). I only lose my place when moving the knee.
What really stumps me about this is that the DRO and even the hand dial do not show that the table has traversed in X, despite where the center of the spindle ends up with respect to the work piece.
Like I said earlier, I do not own this mill. Regardless of this, I do my best job to take good care of it for several reasons. The first being that the school's technician responsible for this machine has been kind enough to allow me unrestricted access to it. I do not take this privilege for granted and am very grateful for the opportunity. Secondly, I see these machines as finely tuned works of mechanical art with astounding manufacturing capability, and appreciate them as such.
Despite my efforts to maintain the mill's health, I cannot always monitor it. Every now and again, the wrong person may find their way into the shop, and slam some worn out cutter into a piece of steel, throwing the head alignment into outer space. I am sure years of this have gotten to the poor thing, and some component somewhere has finally given out.
Hopefully someone has fixed a similar issue or can identify some component that is leading to this problem.
Thanks a ton for any advice that anyone may have!
