RC99
- Mar 26, 2005
How much spindle deflection should there be in the spindle on a bridgeport..
The one I have if I put a DTI on the spindle itself and press against the opposite side I get 0.001" movement with moderate pressure... If I put the DTI on the quill and do the same there is no movement meaning the sideways movement is in the bearings... This is for a cold spindle
Is this amount of movement normal??
If it is not normal and since the bearings are not easily adjustable for preload do you grind the inner tube between the bearings a "tiny bit" to get rid of this movement or get new bearings?
