Rocketdc
- May 24, 2020
I read a few threads on the various symptoms and solutions for table slop so I'm relatively familiar with what's going on with mine. Typical older mill with worn ways and feed screws. I took the table apart to remove the hardened grease and familiarize myself with how everything ties together.
The feed nuts look like they were cut ~3/4 of the way through compared to the newer two piece design. Would there be any benefit to replacing the nuts and reusing the worn feed screws? Seems like it would be kind of pointless replacing one without the other, but maybe I haven't thought it through well.
Before I took the table apart I tightened up the gibs and found the typical tightness at the less worn ends with still a bit of slop in the middle of the X travel. Since I was still able to tighten the gib am I correct thinking there wouldn't be any benefit to try and shim them since the wear is uneven across the length of travel? So the only real remedy for tightening up the table slop in the middle would involve regrinding the ways? This machine is too old and underpowered (3/4hp) to warrant much investment so I'm just trying to find the most cost effective solution to get it performing a little better. I realize it may already be too far out to pasture for that.
