bridgeport tilt worm gear measurement
Likes Likes:  0
Results 1 to 4 of 4
    Dec 2010
    georgia, usa
    91
    28
    19
    Default bridgeport tilt worm gear measurement
    I have a supermax step pulley head that is missing the worm gear which tilts the head. I know supermax does lots of stuff different (i.e. parts don't swap) from genuine bridgeport stuff. With that being said can anyone point me in the direction of dimensions of the worm so I can measure and see if I can order the readily available bridgeport part or if I need to source the supermax part. Or if anyone knows if the worm is a direct fit. Thanks!
    Dec 2013
    Fort Wayne, IN
    715
    777
    256
    Barry said that it most likely wouldnt fit, but that chances are you could replace that gear and the one in the knuckle with a BP one and theyll mesh.
    We do have a box of Supermax parts, if you wanted to call and talk to him about it, he can see if he has one. 800-285-5271
    Jon
    H&W Machine Repair
    Dec 2010
    georgia, usa
    91
    28
    19
    The base that I have is actually a Jet jtm-1050. I would most likely replace both gears just to have everything in there fresh. I know its an unholy union of import clone parts.
    Thanks, I will give a ring at some point.
    Apr 2018
    3,707
    1678
    Quote Originally Posted by raven007 View Post
    Measure your center distance. That's what counts.
