69fordgt
- Apr 21, 2019
- Southeast Iowa
I'm having an issue with my V2XT DX32. I was using the jog dial to move close to the positive limit on the Y axis and contacted the switch which stopped travel and set a limit fault. The switch failed to make up again when I got away from it and had to be replaced. I am no longer showing a limit fault but now at startup it goes to an axis fault as soon as I press 7 to engage the axis drives. The contact to engage the drives pulls in and drops back out within a second. Is there some reset that I need to do to clear the fault or has anybody seen this happen? It was working fine until the limit switch contact.
