Bridgeport Weight
Results 1 to 18 of 18
    Jan 2011
    Massachusetts
    149
    Default Bridgeport Weight
    Hi All,
    I may be looking to buy a Bridgeport in the future but need to know the approximate weight as it will be going in a space that may be hard to get it into. Also, how big of a door does it need to fit through? Can one easily be broke down to make it smaller and easier to move?
    Thanks in advance
    Russell
    Sep 2007
    Washington
    5,456
    236
    1711
    About 1 ton on the weight. Can't see getting one through a standard 36" doorway without taking the table off, but maybe you could do some rotate and shimmy thing and move the table back and forth .
    Regards.
    Mike
    May 2003
    Iowa
    10,490
    3616
    4285
    Base 9*42 machine is 1988 per BP. A couple of years ago, Milicron posted pictures of getting a BP through a 36" door. It all depends on how much room you have on either side.
    JR
    Dec 2004
    Central IL, USA
    1,179
    56
    105
    Bridgeports move like cake with a standard pallet jack. Just don't tip it over.
    They can be taken apart with an engine crane. I have read of guys disassembling them so they could put the machine in a basement. Winding the table left and right will get you though a 36" door if you take it from an angle.
    Jan 2011
    California, USA
    Default If a Gorton Mastermil will fit, a Bridgeport oughta'
    The angle through the 36" door thing works but you will have to wind the table back and forth a couple times to walk it in. I got my GORTON 1-22 Mastermil through a 36" doorway just barely and it's a bulkier mill. I had to rotate the head down since the motor was higher than the doorway, so check your height too.
    The best tool I've found to shimmy a big mill around is a long crowbar thing about 6 foot long. I inherited mine from some old guy years ago. Now I'm the old guy. It's basically a long hex bar about an inch across flats with a slight bend at one end that tapers down to a flat end like a crowbar. Just get it under the machine and lever against the floor and swivel. Even a big machine can be coaxed into a corner.
    Hope you find your BP.
    =vonzapp=
    Jun 2006
    1,537
    40
    Quote Originally Posted by vonzapp View Post
    It's basically a long hex bar about an inch across flats with a slight bend at one end that tapers down to a flat end like a crowbar. Just get it under the machine and lever against the floor and swivel. Even a big machine can be coaxed into a corner.vonzapp=
    Better known as a 'Peavy Bar' I believe.
    pg
    Sep 2007
    Washington
    5,456
    236
    1711
    Mine has a label that says, "Slate Bar". I guess it'll come in handy if I ever find work at the nearest slate quarry .
    Regards.
    Mike
    Jan 2007
    Auburn Ma
    783
    25
    64
    Russell...I have this reconditioned Bridgeport for sale in Mass
    http://www.practicalmachinist.com/vb...rt-f-s-216992/ JOHN
    Aug 2008
    Sussex, England
    3,449
    13
    779
    Quote Originally Posted by A_Pmech View Post
    Having seen it happen I can confirm that a Bridgeport makes a very impressive bang if it does go over!
    Not, in my view, a job for those unskilled with or unused to pallet trucks. Best to spike it to a pallet first if you can arrange the lift. Unless your route is real smooth with no sharp turns or shunting around I'd also arrange some timber "sort of H with bottom rail" shape frames to strap under the table set to 1/2" or so off the ground by adjusting the knee. Put them close to the table ends so it can't tip far. Then if it does make a bid for freedom everything ends up safely parked up whilst you figure out what to do next whether to just adjust the knee for a bit more clearance and carry on, arrange extra supports or whatever. Naturally use a proper industrial rated pallet truck. Some of the imports are horrifyingly flexy.
    Generally up to "a ton and some change" lifting'n shifting is basically common sense, not getting underneath the load and making sure that things can't go very pear shaped before parking up secure whilst you figure out what to do next.
    Clive
    Sep 2007
    Northern Illinois
    2,980
    1628
    1802
    Quote Originally Posted by piniongear View Post
    pg
    To me, a peavey is a cant hook with a point, used for flipping timbers:
    Welcome to Peavey Manufacturing Company
    What is being talked about I would call a "stevedor bar", but McMaster just calls it a Offset-Chisel and Pointed-End Bar
    The 60" length is plenty to move a Bridgeport, and the machine even has a baring slot in the front center of the base casting.
    Dennis
  11. #11
    Jun 2010
    Missouri
    356
    8
    Pinch bar.
    It'll pinch crap out of anything it traps.
  12. #12
    Dec 2007
    San Francisco
    442
    Roll a Lifts work real well with a B Port as well. But they wont get you thru a 36" door.
  13. #13
    May 2003
    Iowa
    10,490
    3616
    4285
  14. Likes Engmaxx liked this post
  15. #14
    Dec 2004
    Central IL, USA
    1,179
    56
    105
    Quote Originally Posted by JRIowa View Post
    Slow day at the office?
    I searched for that link off-and-on for at least half an hour last night.
    Nice find.
  16. #15
    May 2003
    Iowa
    10,490
    3616
    4285
    Actually, no!
    Snow last night so SWMBO wanted to leave for work early. We work about 1/4 mile apart. The roads were good so I was in very early. Took about 15 min. to find.
    JR
    BTW, it's lunch time now and I have to get back to work.
  17. #16
    Jan 2010
    Indianapolis, Indiana, USA
    5,467
    2426
    934
    Quote Originally Posted by AeroE View Post
    Pinch bar.
    At least where I've been, it's a pinch bar.
    Home Depot, Lowe's, etc.
  18. #17
    Oct 2008
    Central PA
    559
    40
    Default Bridgeport fits through doors with table on
    When I moved mine, I recall the 2J head model being quoted as 2100 lbs.
    I moved mine through a 36" cellar door using the wiggle method. A few shots of the move are found in the metal working dropbox from 2009. The file is called " Moving_a_Bridgeport_2J_Head_Milling_Machine_2.pdf"
    If this link works, it will open directly for you.
    http://www.metalworking.com/dropbox/..._Machine_2.pdf
  19. #18
    Apr 2013
    West Virginia
    63
    33
    We also call them digging irons.
