mvernon
- Feb 10, 2019
- Pennsylvania
I am in the process of fixing and cleaning my bridgeport round ram. The x axis works as it should although worn. How ever the Y axis is extremely tight. I had originally thought this was because the feed nut assembly was damaged and they had tightened the feed nut retaining screw too much. However with everything disassembled the nut runs freely on the ends of the screw and is very tight in the middle of travel maybe 3-4 inches. Not sure if i need just a new nut or an entire lead screw. Ideas?
Thanks Matt
Thanks Matt
