moonlight machine
- Nov 19, 2007
- marysville ohio
The Y axis nut had about .050 lash as read on the dial. Suddenly it has .200 lash. So I figure the adjuster screw backed out. So I remove the Servo power feed and the bearing block to make a quick adjustment. Much to my surprise there is no adjusting screw. I removed the lead screw for a better look and discover the nuts are one nut with no apparent adjustability. The slop is the whole nut moving in the trunnion. Can I tighten it up without a major tear down? I have quite a bit of work right now and need it up and running. It is no garage queen, it works for a living every day.
