Cleaning up bridgeport mill - Page 9
Page 9 of 9 FirstFirst ... 789
Results 161 to 162 of 162
  1. #161
    Aug 2019
    Alabama
    Oh speculation is rampant here, if I made as many inferences as a lot of “pros” do on here, I’d be fired tomorrow. Anyways, you can use electrolysis to clean the metal for sure, BUT just make sure the metal you use as your anode is cast iron as well, using different metals or graphite could lead to removing good metal. I won’t bother explain how that works unless you care to know, just respond if you’d like a more detailed explanation. Oh and due to its carbon content, the cast iron will come out black after electrocleaning, but this is easily brushed off and leaves a nice clean piece. Good luck!
  2. #162
    Feb 2019
    Colorado
    17
    IMo it is very unlikely that the usefulness of a machine table could be destroyed by rust.
    "Removing the rust" with acid or electrolysis is a complete waste of time. Only the actual "surface" of the surfaces are important, so SCRAPE off the rust that is ON the surface with a flat scraper, stone the surfaces flat, and your done.
    Non critical surfaces and impossible to reach spots, areas that will be painted; wire brush.
    I never did anything special to clean the rust off some areas my tools or machines, just used them properly, keep it oiled and wiped off, and it fixes itself. Rust is a polishing agent, low spots in the surfaces hold oil and can improve lubrication.
    Although....those rusty quill pics on the last page are terrifying!
    But even if the head is goner, it could be replaced. They made 3x more heads then they did mills. For adapting to other machines, or 2 head tracer models which aren't much use today.
