climb milling switch?
Likes Likes:  0
Results 1 to 9 of 9
    Dec 2016
    TAIWAN, PROVINCE OF CHINA
    174
    11
    Default climb milling switch?
    On the new Bridgeport style mill I got I noticed an adjustment on the front of the table itself. It shows a symbol for conventional milling and climb milling. I wonder if any mills have a "switch" like this and what does it do, engage the nut in such a way that climb milling doesn't cause problems?
    Oct 2018
    ALAND ISLANDS
    35
    12
    Sounds like some sort of anti-backlash mechanism. Could you post pictures?
    Mal
    Dec 2016
    174
    11
    I will try as soon as I get home... the mill is sitting under a tin roof outside because I couldn't get a crane operator to get it up to the second floor. That roof will eventually get turned into a shop. Not ideal but I get 3 phase power and it will make future machine purchase much easier.
    Dec 2016
    174
    11
    All pictures are coming out upside down for some reason, and trying to trick the software by sending it inverted doesn't work. How can the forum software be smart enough to know??
    anyways this is the adjustment I am talking about. It's some kind of an adjustment that has a picture for climb milling and regular milling. I don't know if this adjusts the backlash or something.
    Jul 2006
    Hillsboro, New Hampshire
    6,258
    1495
    4369
    Removed due to uselessness.
    Jan 2003
    Imlay City, Michigan
    1,819
    86
    179
    Quote Originally Posted by taiwanluthiers View Post
    IIRC, some of the K&T mills had this as an option?
    I don’t recall exactly what it did, you may want to do a search in the K&T forum?
    Kevin
    Dec 2016
    174
    11
    I have yet to try it since the mill is not under power. I have to wait a few weeks before they put walls around the shed and apply power to it so I can try to power it up and see how it works.
    Another thing I noticed on this mill... the ways are not dovetailed, but rather T shaped, like all square and stuff. This is true for all 3 axis. I never seen this on a mill before, I thought they were all dovetails.
    Sep 2009
    Apex, NC
    1,407
    701
    May be some sort of cam/friction device to add some "drag" to the table (same sort of effect you can do by slightly tightening the table-locks) or take up the nut backlash (in which case you probably don't want to leave it "on")? Curiosity got the best of me, attached is a picture of the K&T backlash adjuster.
    Your machine has box-ways, versus dovetail, common for heavier machines.
    Dec 2016
    174
    11
    Correction, the box ways are only for Y axis and knee. X axis ways are still dovetail.
    I tried checking runout by putting a c32 collet inside and a 6mm center drill and it looks to be out .03mm or .0015” is that good? I haven’t been able to check the spindle itself but I got ways to correct slight run outs...
