Guys I have tried everything to remove that small ball from inside the clutch collar but no go.I spent yesterday and couple hrs this morning trying and trying.So I am left with no choice to either cut off the collar or the shaft.I watch some Youtubes on removing the ball but nothing works for me.There were couple Youtubes where just like myself they had to cut off either the collar or shaft but I don't know which one.The collar is 15.00 and I think the shaft is 40.00 but I don't know if by cutting one shaft if that will also cut the reverse shaft. The pic that is out of focus tried to show the ball that is inside the collar.I'm sure that someone here has come across this same problem so before I start cutting what did you do,if you had to cut what did you cut off to get to that dang ball?Thanks for any guidance and suggestions.
