DIY Mill Head Installation Tool
Results 1 to 20 of 20
    Jan 2021
    Ohio
    213
    Default DIY Mill Head Installation Tool
    The BP mill I just bought as a project needs to be reassembled. The previous owner had taken the motor and head off the machine when the motor shaft failed when the key came loose. I'll do a full rebuild at some point, but right now, I just want to get it back together so I can get an inventory of parts I need. Parts that were probably scavenged off this unit over the 10-15 years it sat.
    Taking cues from Mr. Pete, H&W and others, I set off to make my version of a head installation tool post.
    Feb 2020
    Maryland
    195
    60
    No need to build a fancy tool. Just grip a piece of round stock in your vise.It is better if you weld a same diameter piece of flat to the round stock, mill two flats on the round stock, or just drill a hole in a fatter piece of stock and insert the round stock. Any of those will give extra support to the vise's grip.
    Dec 2008
    Vt USA
    9,197
    1599
    3302
    Quote Originally Posted by MyLilMule View Post
    Sometimes a bit of compliance can be used to advantage when fitting assemblies. That bit of tooling appears to gusseted well beyond the requirement.
    Jan 2021
    Ohio
    213
    Quote Originally Posted by CalG View Post
    I don't mind overdoing it. I enjoyed making it.
    Jan 2021
    Ohio
    213
    Quote Originally Posted by Superbowl View Post
    You see the irony in this suggestion, don't you? LOL!
    Dec 2008
    Vt USA
    9,197
    1599
    3302
    My thinking was that sometimes. overdoing it, makes the required task less enjoyable.
    Dec 2008
    Vt USA
    9,197
    1599
    3302
    What" you don't have a bank of other milling machines waiting for the call? ;-)
  8. Likes MyLilMule liked this post
  9. #8
    Jul 2007
    UNITED KINGDOM
    5,471
    3424
    2820
    I used a slitting saw arbor held in the jaws of the 4 jaw chuck that was on the rotary table a few weeks ago. To be fair, the rotab and chuck were already on the mill so it was a trivial excercise when I needed to get the head off for some work.
  10. #9
    Jan 2007
    Flushing/Flint, Michigan
    10,575
    619
    8543
    I do not understand the why of this or need for it.
    What is the purpose? Most certainly the tram will not be correct and just something close so why?
    What am I missing as to use? I have never seen such.
    Bob
  11. #10
    Jul 2007
    UNITED KINGDOM
    5,471
    3424
    2820
    If you need to get the head off a mill for some purpose (replacing the spindle spline driving bush in my case) and don't have a crane or, like me have a crane but the height is marginal, then this is a controlled way to get the head on and off the ram. Once the head is down at a lower level, the motor can be lifted off safely and the head can be disassembled to do whatever service work was needed.
    I can lift the entire ram + head + slotting head off my mill with the crane, even got an eyebolt at the balance point. Getting just the head off is more awkward since I fitted an 8" riser block.
  12. #11
    Jan 2021
    Ohio
    213
    Bob
    Perhaps it will become clear in a follow up video I am still editing. I needed to put the head back on the ram. It holds the head in a rough position while I line up the bolts in the ram adapter with the holes in the head so it can be bolted back into place. It's an INSTALLATION tool, not an ALIGNMENT tool.
    And yes, there is more than one way to skin a cat. I chose this method.
  13. Likes Mark Rand liked this post
  14. #12
    Feb 2020
    Maryland
    195
    60
    Clearly you don't understand. You use something like a six inch long piece of round but only mill flats on the two inches a vise can grip.
  15. #13
    Jul 2007
    UNITED KINGDOM
    5,471
    3424
    2820
    Hey, they're all means to an end. The significant thing is using the knee and table to save yourself from broken arms and/or hernias,
  16. #14
    Jan 2021
    Ohio
    213
    I'll just use the mill that's in my other pants.
  17. #15
    Oct 2005
    22,047
    Yabutt, you would miss out on qty (2) hours of welding....
  18. #16
    Oct 2005
    22,047
    You think we need another Video ?
  19. #17
    Jan 2021
    Ohio
    213
    How else will I be able to solicit all of this constructive criticism?
  20. #18
    Jan 2021
    Ohio
    213
  21. Likes seagiant liked this post
  22. #19
    Oct 2005
    22,047
    Rather
    "I need to post here, to get people to watch my videos, to make money"
  23. #20
    Jan 2021
    Ohio
    213
    Rather
    If I added up all the money I made from making videos, I'd have exactly 0 dollars and 0 cents. My channel is not monetized. Nor do I have plans to do such. The only people making money is Google, unless you use an ad blocker like I do.
    But, hey, I do appreciate your honest, misguided, ill-informed, and all around ignorant, commentary!
