Does she have the power?
Results 1 to 6 of 6
    May 2019
    Indiana
    Default Does she have the power?
    Hello everyone.
    I just negotiated a couple of free face mills from my companies supplier.
    I'll link the mills below. One is a 3", 9 flute. The other is a 2", 7 flute. I'm aware these mills were intended for machining centers.
    Anywho, Will the standard ol prototrak bridgeport clone have enough ass for these? Material is soft A2/D2, occasionally 4140.
    by my calculations using 310SFM and a .004" chip load;
    the 3" will run at [email protected] 400mm/m for the continental types.
    the 2" will run at [email protected] 420mm/m.
    That sounds like alot of action for the machine. Is it recommended to run at the high end of low gear? Don't want to ask for a batch of inserts after the first attempt lol.
    all advice appreciated. Just an apprentice doing apprentice things.
    Many thanks
    2"
    Mitsubishi Materials Web Catalog
    Products Information
    Face Cutter
    APX3000-A_INCH
    APX3000R0207A
    3"
    Face Cutter
    APX3000-A_INCH
    APX3000R0309A
    Dec 2004
    uk
    14,058
    4552
    6696
    IMHO there a bit fine tooth count wise, i like a SEHT 2" has 4 inserts 3" one has 5 inserts if i remember right. IMHO you kinda have more inserts cutting than you need - can power with thoes. I will say my Bridgeport does well with the 2" one in steel, they really shift some metal and are very free cutting. Can take a fair depth of cut and wind the feed on, lower end of high gear works prety nice. That said i don't do much alloy steels with thoes, its normally plane 3b mild steel, but they sure eat it up!
    Never had as much luck with a square face mill on the Bridgeport, kinda find they beat the snot out of the little girl. I do use APKT inserts though a fair bit, but even then you don't get to go at all deep with them on a Bridgeport.
    generaly i use my 3" and bigger still 80mm 45 degree lead angle cutters for faceing non ferrous stuff, were its fair to say they realy eat it up, they make a great snow storm in pretty much any white plastic going!
  3. Likes DavidScott liked this post
    May 2019
    Indiana
    Thanks for the reply! I agree the there is alot of cutting edges. My experience in tool variations is very limited.
    They were free to me, so even if they aren't practical, they're still beautiful toolbox ornaments
    I suppose I'll just give them a go and try not to turn too many heads lol
    Dec 2016
    TAIWAN, PROVINCE OF CHINA
    177
    12
    If the cutting edge is too many, what about removing a few inserts to reduce its cutting edge and therefore HP requirement?
  6. Likes Winterfalke liked this post
  7. #5
    Mar 2011
    Huron
    1,341
    1856
    834
    Quote Originally Posted by taiwanluthiers View Post
    I was going to suggest this, I've certainly done it myself when I ran low on inserts or had a damaged pocket or insert seat? (forgot what the carbide pad under the insert was called lol). I've also seen a large facemill run with only one insert and a simple lead weight opposite for balance to give the effect of a flycutter for finishing reasons.
  8. #6
    Sep 2010
    Oklahoma City, OK
    3,972
    689
    1696
    Quote Originally Posted by Winterfalke View Post
    I believe that's called the anvil.
