Jacob Didsbury
- Oct 21, 2013
- United Kingdom
Hi all, Im in the process of tiding up my brideport mill, not had it long just trying to get everything working up to scratch again.
It has a Anilam Wizard 150 DRO fitted to it both X and Z axis work great however the Y axis readout isnt working right, it just flickers when you move the table along the Y axis, or jumps.
I check the wires seem to be ok along the path to the readout unit an the connections to the unit too are good, so I wiggled it around on the slider itself, nothing.
So I decided to unbolt it from the knee, moved it back an forth along the scale an it just flickers, so I stripped it down never taken one apart before but thought id have a look, its a glass type one inside also had a small ball bearing that came out, cleaned the slides down inside an managed to get the ball bearing back in place an fitted it back togther (bit fiddley) still doesnt work, but if I move it really really slow it does actually work, the little plastic strip that goes on one side of the glass scale seems to drag back abit rather then move with the slider wondering if it needs to be fixed with the slider and something has been lost if its been apart before? if not may have to get a new scale
Any thoughts be appreciated
cheers, Jake
cheers, Jake
