Edge finding that does not mare the work. - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21
    Jan 2007
    Flushing/Flint, Michigan
    10,453
    604
    8479
    Marring the work with and edge finder may be a matter of what the work finish is and how soft it is.
    If I had to finish the back end of a small mirror mount with the mirror attached so as to hold back length I would not hit the mirror with an edge finder.
    Normally of no concern but I'd bet that if you get your 1500X microsope out all rotating edge finders marr the work piece in conventional materials.
    If you have one micron readouts every notice that such edge finders "snap" in just a bit from hit one to hit two? Second a tad more and then three,four and they settle down.
    Bob
  2. #22
    Dec 2005
    UTAH
    590
    101
    64
    I've been using a Starrett edge finder for over 45 years and I've never seen one dent the edge unless I've crashed in one. I have a 3D tester but find the edge finder better suited and easier to use mostly because I don't like dials with .001 resolution. You have to be looking straight on to get the best reading. With an edge finder it doesn't matter where you your standing. I find that I can repeat to within .0002 with the edge finder in the CNC and with a manual machine .0005 is about the best you can expect. A $300 3D tester would be a waste of money on a manual machine.
  3. #23
    Aug 2019
    145
    17
    19
    Bob
    If it takes 1500 magnification to see it, then I would think it could be easily buffed out with a cotton rag. With my 4 mag old man's glasses I could not tell you where the finder touched just from looking, even on soft delrin.
  4. #24
    May 2020
    Indiana
    31
    6
    I'm inclined to think that Edge finder sucks. Even in the video on the page he linked it did leave a small mark on the part. I've got an old 1/2" Brown and Sharpe someone gave to me and I can't say I've ever noticed anything left behind.
  5. #25
    Dec 2008
    Vt USA
    9,066
    1542
    3239
    I keep a pack of Zig Zags on the mill ram. a paper placed between the work (lick it and stick it) and anything in the quill will pull away when the paper is pressed. Call it, .001- .0015". (mic the paper if you want.)
    No contact,,, works every time, no fancy optics needed...
  6. Likes Paolo_MD, Scottl, Dumpster_diving liked this post
  7. #26
    Mar 2009
    6,118
    116
    1201
    Today I put my edge finder on the top tray of my tool cabinet. I then I said to it that you are a piece of shit and I'm not using you. Instead you can watch me
    sight in the center postion for some holes.
    Brushed some blue and a scribed a few lines. Then I cut a point on a 3/8" bar and chucked it. Used a 10x eye piece and centered the point of the bar.
    Hole position was .001 off. So for a hole that has some slop for a screw the position is good.
    I use a caliper with the distance set to slightly less than half distance across the piece. The mark a line from each side. Then I just dial in between the lines.
    It works pretty good. As I tap the handle for position I know the movements are in less than .001 increments.
    Then I looked at the edge finder and said "you can drink paddy water now".
  8. #27
    May 2011
    New Jersey
    2,943
    290
    1617
    I'm still rather amused at this conversation...
  9. Likes moldcore liked this post
  10. #28
    Feb 2014
    FL
    4,321
    13572
    5150
    Uh, if your bar is a known, consistent width, why are you not just edge finding the fixed jaw of the vise and moving over half your known width?
  11. Likes Dumpster_diving liked this post
  12. #29
    Sep 2009
    Apex, NC
    1,714
    860
    And, aside from cheapo eccentric edge-finders that won't work, a microscopic nick or any abrasive on the sliding edges/faces will make it inoperable and/or unreliable. If the faces get scratched, might as well trash them. I also use them frequently for centering holes on round features/stock using the DRO, if the accuracy of indicating the hole isn't required: eyeball center and pickup one side of feature with ef, zero DRO, pickup other side with ef, divide by two to get center, repeat for other axis. Good for .0005"-.001.
  13. #30
    Nov 2013
    Eastern Massachusetts, USA
    7,011
    5969
    6391
    The electronic edge finders are great but are only made with .500 shanks. Often you want to use one with different size collets and I've been toying with the idea of making ones with ceramic spacers as centers and then grinding the ends to final size. They could then be used with any continuity tester. There are circuits posted on the internet that measure the resistance through the spindle etc. all the way back to the work holder but they are finicky to adjust and not all that convenient.
    Quote Originally Posted by CalG View Post
    I was shown that trick many years ago and it does get you within a thou or so. For the uninformed, Zig Zags are a brand of cigarette paper used to "roll your own" (filling choice optional).
  14. #31
    May 2003
    5,604
    23
    813
    The non rotating electronic edge finders are only accurate if the contact is on the same spot, or mark your device so the work contact is on the same spot on the probe.
  15. #32
    May 2017
    Massachusetts
    406
    445
    206
    As others have said, it should not leave a mark. Something is wrong. Regardless, if you can’t sort that out:
    1. Interpose something sacrificial like zig zag paper or even thinner, bluing.
    2. Indicate off the vise jaw, going the other direction.
    3. Add a shim of a known dimension (like a .100 block), indicate off that, then subtract the known dimension.
  16. Likes Zap921 liked this post
  17. #33
    May 2003
    5,604
    23
    813
    Pros would go for the electronic probe, but reasonable results can be had the old way.
  18. #34
    Sep 2007
    Northern Illinois
    3,032
    1666
    1845
    A toolmaker would just hang an Indicol on the chuck and tram it in with a test indicator. Then you know you on center.
    Dennis
  19. #35
    May 2003
    5,604
    23
    813
    Yes indicating a part in is tried and true.
  20. #36
    Nov 2014
    Florida
    6,262
    2488
    3100
    Quote Originally Posted by DanielG View Post
    The Haimer Zero Master model is 10mm shank and <4" long, so if you're running a 1/2" drill chuck it should fit.
    I've never used one, so ..? Don't they have to be indicated in to be accurate?
  21. #37
    May 2003
    5,604
    23
    813
    "Don't they have to be indicated in to be accurate?"
    I think so, I test the part on the high point of the probes run-out, found with an indicator "Accurite probe"
  22. #38
    Feb 2001
    Redwood City, CA USA
    5,296
    236
    1157
    Yes, you need to get the ball runout as small as practical. If the ball is offset, then so is the location of zero. Setting and periodically checking the runout is the major use for my tenths indicator. The runout typically stays small, but a hard bump could upset it. You don't want to run off a big batch of bad parts because your Haimer developed runout and you didn't know it.
