amegger
- Apr 30, 2014
- missouri, usa
I have a 1995 eztrak dx 2-axis that is regularly having both axis drives fault. The axis movement stops during a cycle but doesn’t have any alarms on the screen. Checking in the panel both drives are faulted and the green light on the bmdc is off, the top red light on the bmdc is glowing dimly with the lower red light off. After the fault the axis positions don’t update when manually moving the axis. After a reset the machine will home out and function normally but will fault again within 5 minutes.
Anyone have an idea what is going on here? Is the software locking up? Bmdc issue or a bad drive?
