Installed a Dorial Tool right angle head on the Bridgeport this evening. I had some light face milling work to do on the end of long part. I switched the machine into reverse and turned it on again, it locked up the head.
I took it apart and found nothing obviously wrong with it, with exception to the main bearing seems to be frozen now.
Well lubed and in good shape, so I am thinking that reversing it did it in?
For posterity; I tightened the taper into the spindle prior to locking down the head, as to avoid pulling the bearing apart, so that is not the issue.
Thank you for any help.
