Found Bridgeport Mill: Buying Help?
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Default Found Bridgeport Mill: Buying Help?
    Hi All,
    I finally found what I think is a good condition Type JV vertical mill but I don't know a lot about them so I am hoping you could help me determine if this is a good deal and what to look out for. Price is $1000 CAD.
    Here is what I know: ways look really good, less than 1/4 turn play of X and Y axes handles, working DRO, minimal tooling, 1 HP, not heavily used, sounds good and smooth running, quill works and comes with what you see in pictures.
    I don't have 3 phase power so I need to get that, recommendation(s)? I am not in a rush to get it up and running.
    Thank you in advance for any advice you can offer.
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    More pictures:
    Aug 2012
    California, Central Coast
    4,975
    2364
    2043
    From the way you describe it is sounds like a great deal, any other tooling with it?
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Last set of pictures:
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Quote Originally Posted by Rob F. View Post
    There really isn't much more than a few old end mills. This was not a machine shop so it was used for specific minimal tasks that didn't involve much tooling.
    Aug 2012
    4,975
    2364
    2043
    With a 1hp motor dont use a static phase converter, instead use a VFD or a RPC.
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    OK, thank you. What is an RPC?
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Also, how much would it weigh? 2000 lb? Trying to figure out moving it from dock level transport to ground level.
    Jun 2012
    Michigan
    12,372
    4183
    4424
    No way, Don't buy that machine.
    Send me the sellers name, phone number and address.
    And I will take my truck and trailer there to give a good piece of my mind.
    looks like a good deal if everything works as it should.
    Brace it so it will not tip forward if you need slam the breaks.
    Don't air gun or WD spray can clean it, but just pick clean and rag wipe it down with a mix of mineral spirits and oil if you wish to clean it, don't wire brush hand wheel dial numbers.
  10. Likes Yan Wo liked this post
  11. #10
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,218
    2393
    1324
    Quote Originally Posted by Engmaxx View Post
    Rotary Phase Converter, better than a static phase converter, cheaper than a VFD.
  12. #11
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Quote Originally Posted by michiganbuck View Post
    LOL. I take it it's a good deal. I will be careful cleaning it as you suggest. Right now I am concerned with moving it as I'm not sure how much it weighs.
  13. #12
    Nov 2008
    Madera county california usa
    2,615
    21
    674
    2000 pounds and do lots of homework before touching it in a move as it can go boom...
  14. #13
    Aug 2012
    4,975
    2364
    2043
    Yes RPC = Rotary Phase Converter and I would also say 1900-2000 lbs on the weight.
    You should lower the table all the way down and you can also rotate the head upside down to lower the center of gravity, this also will make it fit under low openings. Many threads here about moving bridgeports, lots of good reading.
    Dont be the guy that says I tipped it over, now what do I do to fix it?
  15. Likes michiganbuck, Hodge liked this post
  16. #14
    Mar 2009
    5,727
    106
    1113
    If you look up the price on a new vise swivel base it's about $350. The price for the package deal is low enough for anybody.
  17. #15
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Thank you. Yes, I need to figure out how the head turns. I will not tip it!
  18. #16
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Where can I get a manual for this model?
  19. #17
    Nov 2016
    CANADA
    Ontario
    71
    41
    5
    Quote Originally Posted by rons View Post
    Awesome. I just committed to it! Now to move it!
  20. #18
    Dec 2015
    Connecticut
    1,228
    29
    412
    Excellent find
    As posted above, there are lots of videos out there on moving a knee mill, they are very easy to tip over , you may want to rotate the head upside down.
    H+W machinery has a great website with easy to find part numbers for any parts that you may need. Most parts are not expensive ( although you got the mill so cheap you may think they are ) They also have some good people there that can answer questions
    Edit- I see Rob beat me to the head rotation
  21. Likes HWElecRepair liked this post
  22. #19
    Aug 2012
    4,975
    2364
    2043
    Be sure to lower the table before trying to rotate the head, that way if you loose grip on it it will not crash into the table. Probably 4 bolts on the front to loosen to rotate it.
  23. #20
    Nov 2007
    marysville ohio
    10,188
    2890
    6939
    B port vice will work for now. You want a Kurt. DRO is prehistoric, but if it works you are good to go. Servo X axis feed is better than a BP feed. about a grand new now days. Hard to go wrong on that one.
  24. Likes Mike1974 liked this post
