I have a Hardinge Cataract lathe model 49 with serial #366.It is working fine but I'm looking for the "transmission". Right now it is hooked direct from the motor (1725 rpm) to the head stock. I'm hoping Larry will see this and maybe he has a spare he will part with. He seems to have a lot of parts.
Also what year was it made?
Next issue is that it has the "cataract" taper tail stock. Can you just use a finish reamer in MT 1 or should you bore it first and then use the reamer?
Todd
Todd
