Hardinge CHNC w/Siemens 810T battery alarm AFTER replacing battery
Likes Likes:  0
Results 1 to 1 of 1
    Nov 2012
    Maine, USA
    391
    1661
    59
    Default Hardinge CHNC w/Siemens 810T battery alarm AFTER replacing battery
    I just posted this in the CNC machining section, before remembering about the Hardinge section here.
    I fired up the machine today to put a new battery in since it's been several yrs since I've put a new one in. Fired up fine, pull out battery tray, put new battery in and put battery tray back in, but now the "1 ORD 6 Battery Alarm Power Supply" alarm won't clear. Now what? I did verify the voltage prior to installing, 3.6v on the money. Old batt also has 3.6v. Swapping old battery back in does not clear it. Any ideas? Thanks!
    Edit: I'm keeping machine on overnight in fear of loosing parameters if I turn it off.
