metalanton
- Mar 30, 2021
I have a feeler dv59 clone and using a 5c mount chuck backplate. Any tricks to drawing the 5c taper in tight since it does not have the usual springiness of a regular split collet. When I tighten it with the lock ring it seems between teeth on the closer ...loose on one tooth and won't get to next tooth for a tight engagement onto the 5c taper. Closer handle doesnt stay in position when tight
