Have two Hardinge Conquest 42, both early 90's vintage. These were very well built and I have had very little trouble with either one.
I have had some turret issues with one. No live tooling. The turret had loosened up and would get "turret unclamp". Turns out it was a small pin you can access through the turret module. I have had a problem with this before on the same machine, maybe 15 years ago. I pulled the pin and replaced it, turret is nice and snug except now for a slight amount of play, but not sure this is transferred somewhere between the gearbox they use or the belt. It was never this good, so I'm comfortable this issue is solved. However, it seems whenever I turret to station 11, the turret turns slightly clockwise to seat. Seems all other stations are a perfect seat. Any ideas? I know you can go into parameters to adjust, but I think that's the turret as a whole, not just one station.
