Dereksadams
- Feb 25, 2019
okay i'm the maintenance guy for my company and i've been here about a year. The hardinge i'm talking about is a dsm-a chucker with an automatic 5c collet closer if that sounds wrong its because i'm not a machinist. First of all its gotta be from the early 70's or so and its never been maintained properly so its literally a pile of junk, and they wanna spend as little as possible. Secondly i have the air pressure set accordingly. The collet just will not pull the whole way back to hold the part. i tore the whole head apart on that sucker and put new o rings and all that good stuff. the solenoid has been taken apart cleaned and lubed its doing its job. The only thing i can come up with is that the collet is sprung or damaged. but i have no way of knowing because the actual "lead machinist" tells me it is fine. yeah that was a lot to take in but any help would be appreciated. Thanks. P.S. any info on removing the automatic closer and just installing a manual one would be good too. prices?
