steelz
- Mar 22, 2009
- Kirkland, Washington USA
I have a late model HC with the newer style jack screw where the motor is installed from the bottom. I changed the belts today and everything seemed fine until I took the speed to 3,000 RPM. The jack screw raises the pulleys too high and they scrape on something inside the cabinet. When I run the screw all the way up it it looks like it's going to run right off the top of the screw. On my older HC I recall that there was a limit switch and the shut off could be adjusted. I removed the cover where the electrical is for the jack screw motor and there is a rotary like switch in there, but I don't see the adjustment I had on my other machine.
Can someone instruct me on the HC speed stop adjustment?
Thank you
Thank you
