Peter Colman
Stainless
- Sep 22, 2004
- Rugeley UK
I have three Hardinge lathes all with the same variable speed to the spindle where a layshaft carrying two cones and moving double cone between them is moved up and down to alter the speed, this will be familiar to most Hardinge users.
My problem is that I have just replaced the belts and when I run the machine all is well to start with but quite quickly the locking ring on one end of the layshaft becomes loose and eventually the drive stops altogether and the cone on that end comes off.
I dismantled the layshaft on the bench and checked everything, the long key is in place as is the Woodfuff key, put everything back and it happened again. The situation deteriorated by the thread in the locking ring stripping, I cleaned up the thread on the shaft and made a new ring to fit only to have the Same problem.
I would add that the belt tension seem s to be right with the tensioning nut on th emoter plate only on a couple of turns.
Has anyone got an idea.
As always thanks in advance
