Hardinge HLV coolant
Jul 3, 2010
Melbourne Australia
Hi to all Hardinge lathe users
I know that there has been posts in relation to this issue before but am wondering if I have had been given the incorrect cutting fluid.
The fluid that I am using is Hocut 797BU , it’s a neat heavy duty cutting oil.
I have never used a manual lathe that uses a neat cutting oil. I am only use to water based cutting fluid. The lathe is covered in this oil and everything is slippery. I did a big job ( for a clockmaker) and at the end I had more oil on me than the lathe. I was constantly having to wipe my hands on a rag to get rid of the oil.
It’s also hard to keep the lathe clean as the oil keeps all the swarf sticky
Is this normal, or do I have an oil that is far too heavy for this application. Is the lathe always oily?
Thanks Douglas
Ps lathe has been fully restored , bed ground , slid ways reground etc due to previous owners using water based coolant.
I run habcool (heavy cutting oil diluted with mineral oil to a reasonable viscosity). It does a great job but my experience is much the same. Oil slinging off the chuck in mid to hi rpm ops is the big source of mess, I'm using a latheguard shield with a length of rubber conveyor belt draped over it and down between the ways- the guard helps a lot but theres a lot of spray that radiates out below the edges.
I've not experimented a lot with viscosity yet, I'm at a 5w sort of consistency at this point- but I don't think changing that would help the spray off the chuck. I run the same fluid on the turret lathe, it sprays off the collet nose just as much- I have a guard to try on it next job that comes along; much easier to run a turret job with flood coolant so I find its worth the effort to manage the spray.
Chips in the tray are left oily, I generally let them drain for a day or so and use a shop vac to pick them up, using the tip of the slant nozzle to keep a wide separation from the table which tends to pick up the chips but sort-of leave coolant pools in the tray. Keeping the tray clean helps manage the mess quite a bit, it reduces the amount of coolant sitting there instead of in the sump.
Leaving the lathe oily and full of chips for a day to let the coolant drain is counter to my instincts but substantially decreases the amount of cleaning and wiping after a job is done.
Modern cutting tools have been improving for the last 50-60 years since your HLV was built. The need for oil 100% of the time? Just saying.
We have started using Mobilmet 427 lately. It is a clear oil probably equivalent to SAE10 in viscosity.
The HLV-h probably has Mobilmet NU in it but we have not turned the oil pump on in almost 20 years.
Do use those 2 Mobil oils in the production machines.
