Hardinge hlv-h (kl-1) tailstock bearing
Results 1 to 4 of 4
    Dec 2017
    GREECE
    14
    Default Hardinge hlv-h (kl-1) tailstock bearing
    The bearing on my kl-1 needs replacment .
    Do you happen to know the type of the tailstock spindle bearing ?
    As i know hlv-h is same machine with kl-1 so supose same bearings.
    Cant find a similar bearing with snap ring at google with these dimensions ... 14,28mm=9/16in ID , 35mm OD , 15,85mm depth.
    The ID seems to be imperial but the OD metric .
    Any help please ??
    Kostas.
    Feb 2006
    Indiana
    12,256
    515
    3352
    The Hardinge part number is CP0004140. It is probably a special item because of the snap ring, so the most likely source is direct from Hardinge. Possibly a rebuilder of Hardinge machines may stock it.
    It may be possible to find the same size bearing without the snap ring groove and machine the groove yourself.
    I looked at the DV-59 parts list and see it uses bearing number VD0004140, which must be different.
    Larry
  3. Likes cupra liked this post
    Jul 2007
    UNITED KINGDOM
    4,421
    2099
    1928
    Note that 9/16"==14.29mm ID, 1 3/8"==34.93mm OD, 7/16"==11.11mm width is a standard imperial single row bearing size.
    I can't find double row or snap ring bearings in the larger width from my suppliers, but you might be able to make a spacer with a snap ring groove that would work with the standard ball bearing. I thought that the tailstock beading was a double row bearing, the same as the leadscrew bearing, but I might be wrong!
    These are the suppliers I use in the UK
    Bearing Boys
    Simply Bearings
    No connection other than as a customer.
    Dec 2017
    GREECE
    14
    Quote Originally Posted by Mark Rand View Post
    Bearing Boys
    Simply Bearings
    I have seen this type of bearing 1622-2RSNR but the OD on the tailstock screw shaft is 35mm , 1 3/8 is very close but i dont think it will be possible to fit in the screw shaft.
