Hardinge HLV-H Metric threading setup issues - HELP please!
Results 1 to 16 of 16
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Default Hardinge HLV-H Metric threading setup issues - HELP please!
    Hi folk
    Well I've owned HLV-H's for many years but NOW have a problem that I just can't get my head around!
    I've now a HLV-H Metric (Made by Hardinge UK) and it's the first time ever I've needed to cut an Imperial 1/4" UNC (16TPI)
    For that option with a Banjo and gears shown on page 69 of the Operators Manual, it states:
    16TPI / Knob 2 / 1st gear on stud 25T / 2nd gear on stud 40T / Screw gear 60 / Idler gears 2x 66T
    Now there is NO WAY if I'm correct that the Banjo can take this setup ... I "Think" I've got the correct Banjo but I've tried my other one too and this does not work either.
    I can get near to the setup if I produce a "special" bolt to hold the 25T/40T as the standard on is too short and I'm not aware of needing a "Special" longer bolt"
    CLEARLY I've done something wrong but WHAT???
    Many thanks in anticipation
    John
    Apr 2005
    Maine
    322
    26
    17
    Just waking up here, no coffee yet. But perhaps you can try running smaller idler gears? It seems odd that they would call for such big gears for the idler.
    Feb 2006
    Indiana
    12,787
    650
    3775
    "I've now a HLV-H Metric (Made by Hardinge UK) and it's the first time ever I've needed to cut an Imperial 1/4" UNC (16TPI)"
    I don't have that sort of lathe, but I do know that 1/4 UNC has 20 TPI, not 16. It is 3/8 UNC that has 16 TPI.
    I don't know if that helps, but I want to be sure you are trying to set up the correct pitch.
    Larry
  4. Likes Stradbash liked this post
    Jul 2007
    UNITED KINGDOM
    4,723
    2487
    2291
    Swap the location of the 60T idlers and the 25/40T pair. That should allow it all to work. (I think).
    I have enough problems due to the fact that I've got a mixture of 22DP (Hardinge) and 20DP (Myford) change wheels!
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Quote Originally Posted by cinematechnic View Post
    I did think about smaller iderlers but surely that would affect the overall speed???
    ... and the question still remains why would Hardinge publish gear combinations that don't work on their accessories??
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Quote Originally Posted by L Vanice View Post
    Larry
    Well that certainly is one STUPID mistake Larry ... Doh!
    I am wanting to cut 1/4" UNC so for that the second gear on the stud goes up by 10 so now its a 50T
    While writing, looking at image 2 and 5 ... The manual states using the Metric attachment - which is which? (I got both with the machine)
    Many thanks
    John
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Quote Originally Posted by Mark Rand View Post
    Hi Mark - THanks very much, will try that now ... While writing do you have a Metric or Imperial HLV-H?
    Many thanks
    John
  9. #8
    Jul 2007
    UNITED KINGDOM
    4,723
    2487
    2291
    Quote Originally Posted by Jersey John View Post
    John
    Neither, I've got a 1952 HLV (no -H), Imperial+Metric dials, Imperial leadscrew+box and a metric change wheel banjo.
    As for using different sized idlers, it doesn't matter. 60/60 is the same as 38/38 etc.
    The Hardnge numbers should work. I haven't got the manual/diagram for the metric lathes, but for the Imperial lathes there were two diagrams showing different layouts. Have you got the book of words?
  10. #9
    Mar 2007
    England UK
    1,805
    753
    738
    Mark if you're in need of 22dp gears cut the blanks and I'll glue the teeth on them for you
  11. Likes Mark Rand liked this post
  12. #10
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Hi Mark, I'm sure we've both got the same manual (Imperial) ... and it just offers two pages to a Metric lathe gearbox setup for imperial threads (P69/70).
    If I could have got away with a die I would LOL
    John
  13. #11
    Feb 2006
    Indiana
    12,787
    650
    3775
    ...While writing, looking at image 2 and 5 ... The manual states using the Metric attachment - which is which? (I got both with the machine)
    Many thanks
    John
    On a common USA HLV-H with inch gearbox and 10 TPI lead screw, the standard gear bracket for cutting inch threads not in the box is the smaller (one slot) and the metric bracket is the larger (two slots). So I suppose you need the one with two slots to mount the 127 tooth conversion gear to cut inch threads on a metric machine.
    Larry
  14. Likes Billtodd liked this post
  15. #12
    Feb 2009
    Colchester UK (where the lathes used to be made)
    1,893
    1306
    549
    I've setup a similar imperial thread on one of the metric lathes at work . I couldn't for the life of me remember how , but Larry's reminded me that you need the thicker metric banjo in order for the gears to run past each other and the shafts.
  16. #13
    Jul 2007
    UNITED KINGDOM
    4,723
    2487
    2291
    I didn't look closely enough at John's pictures. You definitely need the two slot banjo, as on the bottom picture!
  17. #14
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Larry
    Thanks for that Larry ... that's another bit sorted out
    All the best
    John
  18. #15
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Thanks Mark - as always, greatly appreciate the imput!
    John
  19. #16
    May 2015
    UNITED KINGDOM
    1,087
    247
    299
    Quote Originally Posted by Billtodd View Post
    Hi Bill - Thanks very much for your input, appreciated as always.
    I'm away for a few days but I'll try a new setup when I get back ... hopefully I'll get it right.
    John
