Hardinge HLV-H treaded spindle nose
Likes Likes:  0
Results 1 to 8 of 8
    Jan 2005
    The Netherlands
    5,581
    249
    1374
    Default Hardinge HLV-H treaded spindle nose
    Title says it
    I am looking for a drawing of the threaded spindle nose of a Hardinge Kl-1 which is identical to a HLV-H
    Or a place where I can purchase one
    Peter
    Feb 2006
    Indiana
    12,576
    593
    3586
    I have never seen a drawing of the 2-3/16-10 RH threaded spindle. I have a Hardinge HV4N indexer with the same spindle end and can take simple measurements for you if you provide a sketch and indicate the dimensions you want.
    Some of the major chuck companies make chuck mounts for that spindle, so they must have drawings. Hardinge might help you if you ask.
    Larry
    Jan 2005
    The Netherlands
    5,581
    249
    1374
    I have a lathe with such a spindle
    What I was curious about were tolences Especialy for the cilindrical part and the threaded part
    Peter
    Apr 2002
    Central Mother Lode, California
    777
    908
    85
    I don't know if this will help but: http://aafradio.org/garajmahal/HV-4N.pdf brings up a brochure on the Hardinge 5C indexing fixtures. Shown therein is a dimensioned drawing for a "fixture" to screw on the spindle nose of the threaded version.
    David
    Jan 2005
    The Netherlands
    5,581
    249
    1374
    Thanks David That might help some
    Peter
    Mar 2008
    Vienna Austria
    255
    83
    61
    While not specific to your Hardinge, the tolerance given by Boley for the register on their threaded lathe spindles is ISO h5, which would seem a good reference point. The document linked by old_Dave lists the Hardinge register as 2.186 (56,6mm), so you end up with an h5 tolerance field of (-0/-13µm). In imperial that would be 2.186" (+0/- 0.0051").
    Machinist meaning of "Register" ? - Page 7
    http://www.tribology-abc.com/calculators/iso_shafts.htm
    h5 is a very precise tolerance, so if you are making matching parts like chuck backing plates, you are probably aiming for a locating fit without interference, which can still be removed by hand, so the mating fit is probably H6, which would be +0/+19µm ( +0/+0,0075").
    Mark
    Jan 2005
    The Netherlands
    5,581
    249
    1374
    The machine came with a back plate for a drive dog
    It has has a very sloppy fit More as 0.05 at least
    The spindle nose measured 2.3/16 " which is 55.56 mm
    So that gives it a sloppy 0.04mm fit according the linked to PDF
    I plan to hold tichter tolerances Perhaps +0.005 +0.015
    Peter
    Jan 2005
    The Netherlands
    5,581
    249
    1374
    Oke
    I had a backplate made Tolerances a bit tighter
    But it did not turn on completly About 5mm left to go
    Finaly we found out the nose is tapered for about 0,05mm
    Peter
