Hi have a nice HLV which when working on turning down a length of rod using a live centre started to make some noises, the more pressure applied from the live centre induced a louder noise from just behind the chuck at the front of the headstock. I removed the part and did checks under various speeds with no load or cutting process, the noise still remains and when you put your ear to the headstock where the taper chuck fitting is there is a distinct 'unhappy metallic sound'.
I've emailed and had a reply from Paul at Babin who is so very helpful even though I live in the UK. He said the HLV spindle bearing are pre=loaded and should deal with any loads applied from a live centre but it seems the noise is from the nose section of the headstock and I can only deduce its bearing issues.
If anyone has had similar or believes there may be other factors please let me know.
If the bearing does need replacing I will need some help with exactly how to remove the spindle unit, I've seen a few online posts (one from csparks.com)and know its a tricky little job. Also require details on the bearings, where maybe to source them (front and back units as will do both).
Any pointers and assistance welcome
Thankyou (sorry the pics are not portrait but cannot find a way to alter the settings - the pictures are the right way round when loaded!)
