Hardinge HLV_H Brake, spring?
Results 1 to 4 of 4
    Aug 2016
    SWEDEN
    Default Hardinge HLV_H Brake, spring?
    Hi,
    I have got myself an old KL1 (HLV H).
    The brake was disconnected and disengaged.
    Now the solenoid seems to work but are buzzing a lot.
    But if the solenoid pulls the lever to disengage the brake then it should have a spring that applies the brake?
    My brake has no spring anywhere it's just "loose".
    Where is the spring supposed to be mounted?
    BR
    Patrick
    Feb 2009
    Colchester UK (where the lathes used to be made)
    2,130
    1566
    693
    The spring it trapped between the lever and the coil cover box. There should be a raised boss on the lever lust behind the solenoid. the spring presses on to the boss.
    The spring is about 25 diameter 30-40 long with wire about 2 to 2.5 diameter. Not super strong .
    Check the solenoid closely for cracks in the copper shorts . This is the main reason for the buzzing.
  3. Likes mellejonker liked this post
    Aug 2016
    SWEDEN
    Thank's Bill!
    Ok, I will start looking into the solenoid and what spring force I might need.
    BR
    Patrick
    Sep 2020
    UNITED KINGDOM
    12
    Default Brake spring
    I had the same problem. I purchased at outrageous cost a replacement spring from Hardinge because I had no idea of the size needed.
    Here are some pictures (if they work!):
    Attachment 323842
    Attachment 323843
    I repaired the solenoid following Bill Todd's advice - fitting two new copper loops. This almost eliminated the noise and vibration. I filed things down a bit t give better contact, maybe I should have done more.
  6. Likes Billtodd liked this post
