I recently removed the oiler tubes in a Hardinge hlvh carriage. I have attached pics of the assembly along with a pic of the one way valve partly dissassembled. I tried cleaning the one way valve in an ultrasonic cleaner but was not satisfied with the lack of air movement(under pressure) afterward, so I removed the packing and the small screen from inside. I then drilled a small hole in the middle of the orface that already had 4 small holes . The first one drilled quite easily, but the second one way valve drilled a bit harder, in fact I discovered that there was also a spring in the little assembly.
I'm curious what success others on the forum have had with cleaning these assemblies.
Markus
Markus
