Hardinge lathe control transformer secondary connection.
Results 1 to 2 of 2
    Mar 2009
    5,643
    104
    1088
    Default Hardinge lathe control transformer secondary connection.
    I was scolded here once about not using the metal frame as a connection for one of the secondary wires from a control transformer.
    A 230vac to 24vac transformer with one of the secondary wires connected to the metal frame and the other wire going to all the control stuff.
    My lathe was built wired this way with a 230vac to 115vac control transformer. Is yours like that?
    Sep 2009
    Apex, NC
    1,575
    776
    Same, mid-80's HLVH has one of the (115 volt) control transformer legs (don't know if that's technically termed "neutral" or 0v, etc) tied to ground, along with the second wire (#8) going to the controls; agrees with the schematic for the lathe. Cheers
  3. Likes Stradbash liked this post
