mellejonker
- Jan 10, 2016
Hello,
I am having my HLV-H apron apart to replace some bearing and solve the problem of a "slipping" handwheel. As can be seen on the picture my poinion gear has been replaced by a spare part gear that was press fitted inside and locked with a through hole pin. When I just bought the lathe the press fit was totaly worn out and I decided to make a bush to restore the press fit, I did not however replaced the pin, cos I thought the press fit would be strong enough on its own.
I was wrong and it starts to slip there, so i took it apart to add some loctite, and also to replace the bearings that hold the pinion gear because they showe play.
Now i also had a change to take a closer look at the 'repair gear' that runs into the rack. It does not look too good anymore unfortunately.
That brings me to the question, can anybody point me to a gear cutter with the correct shape to cut this gear? I learned from old threads it is a specific (old fashioned) shape but when I can buy a matching cutter I would like to give it a try and cut my own.
My lathe is metric, the gear has 14 teeth.
Thanks for suggestion,
Melle (in Holland, even my profile says Afghanistan, i never been there, cant change it though)
