rons
- Mar 5, 2009
- California, USA
The 4 setscrews on the base.
The 2 outer screws push the tailstock because the screw threads are in the tailstock body.
The 2 inner screws pull the tailstock because the screw threads are in the gib.
Looked in more than one manual and never found adjustment instructions.
Heard here that they are not adjustable.
Indicator held on tool post and moved down the length of a 5" cylinder between centers.
With some in/out adjustments to the screws that push/pull I can get the cylinder straight.
Moving the inner two setscrews and the tailstock lever pulls the alignment off and the process(?) repeats.
Anyone every mess around with this and have a way that can be written down in a procedure?
