Hardinge TFB-H Compound Slide Removal
Results 1 to 5 of 5
    Jul 2019
    Connecticut
    Default Hardinge TFB-H Compound Slide Removal
    Looking for some help with a Hardinge TFB-H how to remove the compound slide. I can't figure it out.
    Oct 2010
    Dewees Texas
    2,283
    26
    606
    That screw head looking thing on the right is actually a cam lock. Loosen it and pull it out. I think the compound lifts straight up after removing the cam lock.
  3. Likes Stradbash liked this post
    Apr 2005
    Michigan
    339
    1304
    55
    Quote Originally Posted by FredC View Post
    Yes, what Fred said. Crank the top of the slide back over the bottom half, find the most free spot in the rotation of the locking cam and wiggle/twist it a bit while you pull on it.
    No hammer is required, unless it’s broken...
    Good Luck!
    Oct 2010
    Dewees Texas
    2,283
    26
    606
    My uncertainty comes from I do not do it very often. When I do I am almost on automatic. Like telling someone how to tie a tie. Can not do it without watching myself in a mirror a couple of times.
    Been feeding bars into a screw machine for the last week, when I go over to the rack to get a bar and start back to the operator's side I never am sure if I had already set the bar feed to receive the bar. Sometimes I have to set the bar down to fix the situation.
    Getting old beats dying young though.
  6. Likes Stradbash liked this post
  7. #5
    Jul 2019
    Connecticut
    Quote Originally Posted by Stradbash View Post
    Good Luck!
    That worked thanks. I was trying to hit the pliers with a hammer and it wasn't budging.
  8. Likes Stradbash liked this post
