Problem with a Bridgeport Series II Interact 4 Heidenhain TNC 155
Likes Likes:  0
Results 1 to 5 of 5
    Sep 2019
    PORTUGAL
    Default Problem with a Bridgeport Series II Interact 4 Heidenhain TNC 155
    Hi,
    I got to work this morning and came across the CNC making a error, The display was Orange without mensages of error.
    What could it be? any suggestion?
    Sep 2009
    Apex, NC
    1,479
    728
    Is it actually "doing" anything with the normal startup functions, or is the actual machine dead too, not just the display visibility. I assume you tried adjusting brightness and contrast to see if anything was visible on the display. I had CRT issues with "BExxx" crt display in the TNC2500, almost completely washed out like that, with a gradient in brightness across the screen, but you could still barely read the characters. I ended up replacing all the electrolytic caps in the display board (could be other components in the crt display board also, such as the transformers). There are LCD retrofits available, and it's been discussed here and on the other forum on the method to retrofit. There used to be people selling CRT modules on ebay also.
    Sep 2019
    PORTUGAL
    The problem is on litle fuse on display controller, i change and it turns on and i work with the machine yesterday, and The problem came back today, when I change the fuse it blows when I turn on the machine
    Sep 2009
    Apex, NC
    1,479
    728
    What is the "fuse on display controller". My "guess" is that it is probably something in the display/CRT module. Cheers.
    Nov 2019
    FRANCE
    Hi,
    Today I actually ran into the exact same problem. I was working behind the machine and when I came back in front of it, the CRT screen was "full orange" and no caracter could be seen.
    I have a TNC155, could you tell me where is the fuse located precisely ? Is the display board inside the VDU unit or is it the graphics card inside the TNC ?
