Hardinge TM/UM with Servo II
Likes Likes:  0
Results 1 to 2 of 2
    Aug 2018
    Ohio
    32
    11
    9
    Default Hardinge TM/UM with Servo II
    I found this mill at a local industrial surplus retailer at good price. The table and cross-slide move freely, but the vertical feed screw on the knee is a bit tight. It only came with one collet and no other attachments.
    It looks like it was setup for a production run with the servo feed and chip shield.
    I hooked it up to my rotary phase generator being careful to make sure the generated leg is NOT feeding the Servo II control, just in case. The spindle and drive motor sound great at low and high speeds, but the Servo II wasn't working. I did some research on here and found reference to the manufacturer; Everett at Servo Source responded right away to my plead for help and sent me several documents to help me understand what I had and how to check it.
    I found a broken connection in the pendant cable and also found the single servo motor was plugged into a socket that wasn't being fed!
    It works great now that it's plugged in to the right socket!
    Now I can start cleaning it up!
    Attached Thumbnails Attached Thumbnails img_20190510_192806.jpg   img_20190510_192919.jpg   img_20190510_192823.jpg   img_20190510_192629.jpg   img_20190510_192903.jpg
    Aug 2002
    413
    15
    First time I've seen a Servo drive like this. I like these mills. If you want to use it as a horizontal the parts are around but they can be pricey. Sounds like you are off to a good start getting things working.
