leeko
Stainless
- Jun 30, 2012
- Chicago, USA
Hi all
I'm working on a vertical head for my hardinge TM, using parts I have on hand. I'm planning to use a high speed head from a Versamill, which would be simple enough to bolt onto the overarm support. But, I have this need to make things more complicated....
I would really like a quill. The Versamill head doesn't have one. So, I'm planning to mount the whole thing, motor and all, on a dovetail slide with rack and pinion from a lathe turret.
The simplest way to do it would be again to mount it on the 2" overarm. But, it'll be quite heavy once I'm done, and I quite like the idea of a more rigid mount bolted to the face of the column.
If I bolt the vertical monstrosity to the column, I lose the ability to adjust it in and out by sliding the overarm. But then, the stock vertical head has the same limitation. I'm thinking it's probably not a problem, but I'm interested to hear others thoughts?
If it's not a problem, what would be the optimal distance for the spindle from the face of the column?
Thanks everyone, and happy holidays!
Lee
Sent from my SM-N960U using Tapatalk
Lee
